5295 Discussions
S1200V3RPM CPU Fan Speed at 100%
RRudo
Hi all,
I am an absolute novice with server boards (quite some experience with consumer stuff). I am building a highend audio PC using an S1200V3RPM board. The board boots fine, Win 8.1 installed and runs fine. The issue is that the "Big Shuriken 2" case fan always runs at 100%. BIOS etc. seem to be current (checked with deployment assistant). Does anyone have an idea what parameter I would need to change in the setup of the board to be able to make the fan run slower when the load is low. XEON E3 1265L V3 should really not be producing a lot of heat.
Thanks a lot for any suggestions.
Rudi
Edward_Z_Intel
Check this article:
http://www.intel.com/support/motherboards/server/sb/CS-022809.htm System fan runs too fast or too loud
Here is the latest firmware:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23447 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23447
If you are not using an Intel chassis, select "Other Chassis" and select correct fan configuration.
RRudo
Thanks for the inputs. Probably on my board, the case / fan configuration is incorrectly configured, so all fans run at 100%.
I tried to update the firmware to get to the chassis configuration menu. I downloaded the firmware to an USB stick (FAT32) and booted to the EFI shell.
However the EFI shell is not behaving as described in the documentation. What I get is the following when trying to read the USB stick.
When I do map -r, I get a list of block devices, not fs0, fs1 etc. When I try to change to the file system on the USB stick, I get invalid mapping name.
Surely a stupid beginner's error. Can anyone help me?
Edward_Z_Intel
Seems your USB key is not properly recognized by the system. After you plug it, wait for a while (like 10 seconds) to let it initialize. You should hear a short beep indicating USB device connected. Then run "map -r" to refresh the mapping table.
If it doesn't work, try a different USB key. And yes it needs to be formatted using FAT or FAT32 file system.
RRudo
Hi Ed,
using another USB stick did the trick. THANK YOU!
All quiet on the western front now.
