5224 Discussions
S2600CP invalid dimm configuration
AArna2
hi there i hope someone knows whats going on here
i have the S2600CP motherboard where it works perfectly fine with 2x 2609 cpu´s but will not work with 2x 2660v2 cpu´s
i have updated the motherboard bios to the latest version BIOS - 02.06.0006 i still always get this error
but it will work if i just use one of them i have also check what the led post code means and that came up short
it lights up led numbers 7 6 5 and 3 2 1
i am starting to tear my hair trying to figure out what the problem
the ram im using is 8 gigs on 4 sticks at 1333mhz non ecc and the ram works just fine with the 2609 cpu´s
if i am missing anything i would very much like to hear about it or if you have a magic solution for this
Hello Atil,
Thanks for joining the community.
According to https://ark.intel.com/products/56333/Intel-Server-Board-S2600CP2 ark.intel.com both processor models that you are using are supported by this board, so that should not be the issue.
About the RAM configuration you want to follow the memory population rules depicted on the https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s2600cp/sb/g26942005_s2600cp_p4000cp_tps_rev19.pdf# page=50 Technical Product Specifications document (section 4.2.2.1) for this board. Also processor supported is in section 4.1.
Please take a careful look at this and let us know if the issue persist.
Hope this helps
Jose A.
AArna2
i have been trough the manual and it seems to be of little help
i have tried putting all ram modules channels A and B that did nothing
put 2 sticks in the A channel and 2 in the E channel still nothing i have even tried with just 1 stick in the A1 slot but still nothing
i even tried populating the A1 slot, C1 slot, E1 slot and G1 slot still no change
i did try the A1 slot when i did it with a single stick of ram i tried 3 different sticks of ram still it would not get past invalid dimm configuration
Hello Atli,
Is there any memory slot LED illuminating when you get the error message?
Could you try the following minimal configuration:
2 x 2660v2 processors, 1 DIMM in channel A1 and 1 DIMM in channel E1
Besides that could you please send us the part numbers of the memory DIMMs so we can confirm if they are validated
Jose A.
AArna2
i did try the minimal configuration and still no luck even tried going back a bios version (02.03.003) i was hoping the latest bios was somehow faulty that does not seem to be the case
as for the ram sticks i have they are the following:
mushkin blackline 996677 x4 (2gb stick)
corsair cmv4gx3m1a1600c11 x1 (4gb stick)
hynix hmt325u6cfr8c - h9 x1 (2gb stick)
i can mix all of them when running the 2609 in dual mode or the 2660v2 in single mode but i have been mainly using the mushkin sticks as my primary test sticks
also there are no lights next to the ram slots when i get this error
Hello Atli,
According to our https://serverconfigurator.intel.com/exodus/page?eventType=11&targetPageId=120224 serverconfigurator.intel.com > THOL builder section for this board, from the 3 memory options you are using only the Hynix HMT325U7CFR8C-PB shows up as validated. Mushkin is supported but the particular model you are using is not validated, neither is the corsair.
I think the next step will be to try with 2 x Hynix modules and confirm if the issue persists.
Hope this helps
Jose A.
AArna2
i am going see if i can get my hands on some validated ram because i only have the one stick of hynix ram i will let let you know what happens
AArna2
i was able to borrow 2 sticks of micron ram model MT18JSF1G72AZ-1G9E3ZF
it not strictly approved but they are very close in model number of those approved but they did seem to do the trick it booted right up with both 2660v2
so the next step will be to get proper memory thats on the approved list
thank you for your help it helped alot
Hello Atli,
I am glad to hear that you got it resolved. Its been a real pleasure. We will proceed to mark this thread as resolved.
Jose.
