5184 Discussions
S2600CP4 - does not boot into OS
rkoto
HI
I recently adquired an S2600CP4 Server board, which I have on a consumer grade 650 Watt current PSU, on a test Bench setup, ie: No chasis.
Single CPU Intel e5-2650l and single 4Gb ECC RAM stick for testing
I cannot get it to boot into any OS, I can access web management console and it sits there for hours, but as soon as I try to bot into an OS Win 10 or Ubuntu 18, the system resets and I get a 1-5-4-2 error beep, which is something regarding power.
Please Advise.
Thank you very much
MVooD
posted a file.
MVooD
posted a file.
Carlos_V_Intel1
Hello MVooD, Thank you for the information. Looking at the logs this seems to be a power issue, it could be related directly to the PSU, the power distribution board or the board itself. Do you have a new PSU to test? Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
MVooD
There is no new power supply, there is a second power supply, but it behaves in the same way as this.
tell me the model or part number of the power distribution board
Carlos_V_Intel1
Hello MVooD, Thank you for the clarification. The only way to be sure is using a new PSU as the system is facing power loss. The part number for the PDB is : FUPPDBHC916813 FUPPDBLC916812 Please look at the page 9: https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/s2600cp_configguide_rev17.pdf Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
MVooD
tell me, are FUPPDBHC and FUPPDBHC2 interchangeable?
Carlos_V_Intel1
Hello MVooD, That depends on the chassis you will use, as you mentioned you do not have a chassis it will not be relevant. Basically, the FUPPDBHC2 is an update for the chassis Intel® P4304XXMUXX and the other one for the discontinued models. Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
MVooD
Carlos_V_Intel1
Hello MVooD, We are wondering if you have further questions? Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
Carlos_V_Intel1
Hello MVooD, Hope you are doing fine. If you need further assistance do not hesitate to contact us again. Regards, Charlie V. Intel Customer Support Technician Under Contract to Intel Corporation
MVooD
Tell me, is the FUPPDBHC2 controller suitable for the P4308CP4MHGC chassis?
jgeny1
why this post is here and mine about same mainboard has been moved to :   the Discontinued Products Community ...
France Bashing ? Racism ? or Sergio S. made a mistake ?
https://forums.intel.com/s/question/0D50P00004DbwSKSAZ/how-to-repair-a-cmos-clear-that-turned-a-s2600cp4-in-a-flashing-xmas-wall-
