S3000AH no boot?
I have an S3000AH board that stopped working after a Windows disk cleanup procedure. On power up the LED Diagnostics stop at |OFF|Red|OFF|Red| and the system goes no further. The manual indicates this means "Enumerating PCI Busses." I have removed the Raid controller and the same error occurs. Is this board dead?
Thanks!
Daniel_O_Intel
Possibly. Can you unplug the NICs, and remove anything else that might be on the PCI bus? Any USB devices?
Nothing else is connected to the board. I removed the RAID card as well with same result. I pulled the memory out as well to see if it would beep and it did.
Daniel_O_Intel
Weird. Normally I'd say that's a dead board, but that would never be caused by just running a software program.
Found a used board on Ebay for $55. Swapped it out and everything works now. Old board is now a target for my .45 ACP practice.
What a bargain!
