S3200sh ipmi configuration
OSEN
Has anyone configured ipmi lan interface on s3200sh. I was using http://osdir.com/ml/hardware.ipmitool.devel/2006-07/msg00019.html to configure s5000pal but this procedure doesn't apply to S3200sh.
Regards.
PS: I have posted this message a few minutes ago but i am not sure if have posted it or not so apalogize for double post if it happens
Edward_Z_Intel
You can boot the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2869&DwnldID=18174&lang=eng IDA CD to configure BMC LAN channel, or you can also use the Save and Restore System Configuration utility (syscfg). Visit http://downloadcenter.intel.com and search "s3200sh syscfg"
OSEN
Thanks for the update I will both try syscfg EFI version and IDA.
Thanks al lot.
OSEN
I have used IDA 2.5.1 and configured my system but i still can't reach (ping or sth else. I ping it from the same lan and can't see MAC address of my BMC)
1) I have plugged my network cable to first ethernet port (the one with the 2 usb connection)
2) configured BMC with IDA 2.5.1. Here is my configuration ( have used ipmitool command )
ipmitool lan print 1
Set in Progress : Set Complete
Auth Type Support : NONE MD5 PASSWORD
Auth Type Enable : Callback : MD5
: User : MD5
: Operator : MD5
: Admin : MD5 PASSWORD
: OEM : NONE MD5 PASSWORD
IP Address Source : Static Address
IP Address : 10.0.0.24
Subnet Mask : 255.255.255.0
MAC Address : 00:15:17:27:11:4b
SNMP Community String : AMI
IP Header : TTL=0x00 Flags=0x00 Precedence=0x00 TOS=0x00
BMC ARP Control : ARP Responses Enabled, Gratuitous ARP Disabled
Gratituous ARP Intrvl : 5.0 seconds
Default Gateway IP : 10.0.0.1
Default Gateway MAC : 00:00:00:00:00:00
Backup Gateway IP : 0.0.0.0
Backup Gateway MAC : 00:00:00:00:00:00
RMCP+ Cipher Suites : 1,2,3,0
Cipher Suite Priv Max : caaaXXXXXXXXXXX
: X=Cipher Suite Unused
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
ipmitool sol info 1
Set in progress : set-complete
Enabled : true
Force Encryption : false
Force Authentication : false
Privilege Level : ADMINISTRATOR
Character Accumulate Level (ms) : 60
Character Send Threshold : 96
Retry Count : 6
Retry Interval (ms) : 200
Volatile Bit Rate (kbps) : 19.2
Non-Volatile Bit Rate (kbps) : 19.2
Payload Channel : 1 (0x01)
Payload Port : 623
Can anyone enligthen me what is my err? Thanks for the help
ipmitool user list 1
ID Name Callin Link Auth IPMI Msg Channel Priv Limit
1 true false true ADMINISTRATOR
2 root false true true ADMINISTRATOR
3 USERID true true true ADMINISTRATOR
4 test2 false false true ADMINISTRATOR
5 test3 false false true ADMINISTRATOR
6 false false true ADMINISTRATOR
KAMALANATH_N_Intel
you can use icmd tool to enable the LAN access to BMC.
Below is the steps.
ENABLE LAN ACCESS TO BMC :
icmd 00 20 18 01
icmd 00 20 30 02 01 04 00 00 (Get lan ip source)
icmd 00 20 30 01 01 04 01 ( Set static ip)
icmd 00 20 30 01 01 03
icmd 00 20 30 01 01 06
icmd 00 20 30 01 01 0c
// Set user priviledge //
icmd 00 20 18 47 02 01 ( to enable the user)
icmd 00 20 18 47 02 02 73 75 70 65 72 75 73 65 72 00 00 00 00 00 00 00 ( set pwd "superuser" to root user)
Using Ipmitool:
// to assign the IP to BMC //
ipmiutil cmd 00 20 30 1 1 3
//to setup the subnet mask//
ipmiutil cmd 00 20 30 1 1 6
//to setup the gate way//
ipmiutil cmd 00 20 30 1 1 c
OSEN
I have also used your commands but still no luck. One intel support center told me not to use "0" (zeros) on the IP address changed my ip address to sth else also changed the ip address of the first nic but still i cant ping or see the MAC address of IPMI (I have also used cross cable for that). Does anyone in this list actuall configured and used IPMI (BMC) LAN configuration on S3200sH? I have also used cross cable to verify if something is wrong with the network. I can ping first NIC's IP address but not BMC
Edward_Z_Intel
First make sure you have the latest http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17856 BIOS/BMC firmware applied. Then use the syscfg utility to configure BMC lan channel:
//To assign a static IP address:
<!--[if gte mso 9]> <![endif]--><!--[if gte mso 9]> Normal 0 false false false EN-US ZH-CN X-NONE <![endif]--><!--[if gte mso 9]> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhe...
OSEN
It seems that only way to enable LAN is to use syscfg not IDA (intel deployment assistant 2.5.1 CD) or ipmitool. Even I see and verify configuration with IDA or ipmitool BMC IP is not enabled.So I have solved our problem with syscfg EFI utility.
PS: To connect ipmi using ipmitool you can use: ipmitool -A MD5 -U USERID -P PASS -H 10.0.0.24 power status for S3200sh but for example to connect S5000PAL you have to useipmitool -A MD5 -o intelplus -I lanplus -U USERID -P PASS -H 10.0.0.24 power status (additional -o intelplus -I lanplus )
Hope this helps to everyone in future.
Hi Edward,
I know this thread is quite old and I'm not even sure you are still around.
But I encountered the same problem as here. IPMI on S3200SH not working if configured with ipmitool. I already updated to the latest firmware and did the steps you mentioned above yet still no go.
Any other way to have it configured? The configuration is saved and ipmilan -c /etc/ipmi_lan.conf on CentOS works but I don't get BMC access when it's off. Obviously something is wrong. I am using this in a prototype cluster configuration with Opennode.
Francis
Hi Edward,
Might be a redundant post as I registered to make sure my post can be counted. Not sure though if you are still active as well as the other guy but I hope someone will be able to help.
I'm having the same issues as outlined above. I already upgraded to latest available BIOS and BMC firmware for my board. Any ideas on how to fix this will be of great help.
Francis
Edward_Z_Intel
Did you try to use the syscfg utility to configure the BMC LAN channel?
Hi Edward,
Yes, tried it. Already resolved. Please see my other post on a new topic created.
Francis
Hello.
I try to configure lan access to BMC. I think my problem with zeros on MAC address. How to solve this problem? Command "ipmitool lan set 1 macaddr" don't change mac.
Auth Type Enable : Callback : NONE MD5 PASSWORD
: User : NONE MD5 PASSWORD
: Operator : NONE MD5 PASSWORD
IP Address : 192.168.10.111
MAC Address : 00:00:00:00:00:00
Gratituous ARP Intrvl : 0.0 seconds
Default Gateway IP : 192.168.10.1
: c=CALLBACK
: u=USER
: o=OPERATOR
: a=ADMIN
: O=OEM
scera
I decided not to recycle this server, but upgrade & use it instead.
But I can not get BCM to configure.
There is NO entry in BIOS section (Server Management) and the EFI syscfg gives me error: Unable to load string file
So I see no way to configure BMC. Server is on the latest available firmware 52,40,15
OK, so now I discovered that SYSCFG_PATH (case sensitive?!!!) needs to be set, as per ie. https://downloadmirror.intel.com/16018/eng/EFI_Deployment.pdf https://downloadmirror.intel.com/16018/eng/EFI_Deployment.pdf
but syscfg just hangs, seems that USB is being read constantly, with no output, no matter what syscfg command I try to run
Used another USB stick & this time made sure EFI_SYSCFG folder was in the root of the drive (not a subfolder). That work, but after EACH syscfg command access to USB keyboard got lost (repluging made no difference, hard power off was the ONLY way). Surely it should not behave like that?
scera
A much easier solution is here - /community/itpeernetwork/datastack/blog/2013/10/10/windows-users-can-use-ipmi-tools-too?sr=stream# comment-21354 https://communities.intel.com/community/itpeernetwork/datastack/blog/2013/10/10/windows-users-can-use-ipmi-tools-too?sr=
