5182 Discussions
S5000PSL IPMI, how to access and configure
WBarr5
Hello All;
Just now got my replacement Motherboard in, and it works!! YEAH!!
OK, so the question is this.
How do you setup and configure IPMI on this board?
I am in the BIOS, and for what I have read, it states that it would be in the [Advanced] Tab of the BIOS.
However, I am not seeing it.
BIOS
Version: S5000.86B.15.00.0101
Build Date: 11/09/2010
Doing a Google search, there are people that are using it. So, how do you access it?
Wayne
Hello Wayne,
I was able to find the configuration utility http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g88217001_syscfg_userguide_rev04.pdf User's Guide for this end of interactive support board.
You should find everything you need to use IPMI on this document. Let us know if you need anything else.
Steven V.
WBarr5
I found this.
Configuring the HTTP/S Channel – enable, port # , user type
With this example
syscfg /hc
Which would be
syscfg /hc http 2 enable 80
However, when I run it, it says: invalid switch 'hc'
here is the document
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/c8175506.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/c8175506.pdf
page 15
If this is what I need to enable the web interface, then it seems that it is not going to allow me to do it.
Need some information on this, please.
Wayne
We are going to continue working with this case directly with you.
Steven V.
WBarr5
Hum.
I replied to the message over there and nothing?
No more contact.
So, What is going on?
Check your inbox and let me know if you received a reply.
Steven V.
WBarr5
It's WORKING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oh man, you do not know how good this feels.
OK. I followed the steps on the second post on this thread.
/thread/17676 https://communities.intel.com/thread/17676
I did my jumper, and powered on, waited 60 seconds, powered off, removed the jumper.
(This does a factory Reset on the RMM2 Board)
Then I booted the system.
And I did my IP Address in Chrome, and it gave me the URL of.
192.168.2.100/auth.asp
But it would NOT load.
So, I opened up IE and loaded the URL, and it IS UP!!!!!!!!!!!!!!!!
I am SO excited right now.
ALL IS GOOD!!!!
Thanks to all that stayed with me on this issue, and tried to assist.
Now we know what needs to be done.
And hopefully, this will prove to be helpful to others that come in with the same issue.
Wayne
We are glad that is finally working for you. Thank you very much for sharing the feedback with all the community.
Steven V.
