5324 Discussions
S5520UR RMM Problems (Video socket error)
Hi guys
I have a S5520UR serverboard with the Intel RMM Installed with following firmwares and everything:
System Information
Host Power Status : Host is currently ON
RMM3 Status : Intel(R) RMM3 installed
Device (BMC) Available : Yes
BMC FW Build Time : Jun 13 2011 16:17:38
BMC FW Rev : 00.57
Boot FW Rev : 00.18
SDR Package Version : SDR Package 0.24
Primary HSC FW Rev : 02.09
Secondary HSC FW Rev : (not present)
Mgmt Engine (ME) FW Rev : 01.12.007.0
Local Control Panel (LCP) FW Rev : (not present)
According to this download: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20284 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20284
Issues should be resolved with the Error about the video socket in the console view of Intel RMM, however, I still get this error altough I think and derive that from the system information, that everything is up to date. I read somewhere that with IPMItools I can restart the RMM console thing (without erasing settings) and all is OK then... Can someone help me to do this as a temporary workaround from a Windows client? My server is running ESXi 5...
OK guys, so far I have answerred one question myself, I was able to logon to the IPMI-shell with an Ubuntu machine on my network by installing "ipmitool" and opening a session by using this command:
ipmitool -H *IPADDRESS OF YOUR IPMI* -U root shell
After you open this session, you can do a cold reset:
mc reset cold
Info thanks to: http://treck.livejournal.com/76702.html http://treck.livejournal.com/76702.html
But I would like to get a solution longterm for this issue...
MMISS21
I can SSH from my PC to the IP address that the RMM Website is on and login, but the command "mc reset mc "MC reset cold" gives an error. I am at the ">> SMASH-CLP Console v1.09 <<"</code>
I turned the power off for the server and turned it back on, but still get the video socket error.
If I have my data center actually pull the plug and re-plug, is that likely to reset the RMM?
Daniel_O_Intel
pulling the power for 20 seconds, will reset the RMM.
DSilv11
Valued Contributor III
your code stack is pretty old.
  1. Record your BMC configuration
  2. Update to newer BMC (and the rest of the code stack)
  3. Restore the BMC defaults (fwpiaupd /setdef)
  4. Edit the BMC settings back to your configuration
After doing these steps, I have not heard of the issue returning.
bmc
