SR1200 chassis
Hi
I need help in setting up sr1200 chassis on my network. When i try to install windows 2003 on this it tells me that it can't find the hardrive to install the OS. I have used my driver drivers of detecting the hardrives, but no joy.
Is there a step by step guide on how to set this up, if not what drivers do I need to get windows 2003 installed on this server.
Can you give me a answer ASAP.
Thanks for your time
DJ_DTA
JasonT_Intel
I am assuming that you have a SE7520JR2 board in that SR1200 chassis. If yes, there is a support site specific to that board @ http://www.intel.com/p/en_US/support/highlights/server/se7520jr2 http://www.intel.com/p/en_US/support/highlights/server/se7520jr2 which would allow you to download drivers for the device you are using.
The server broad that i am using is the
Intel
® Server Board SCB2
Hope this helps
dj_dta
Edward_Z_Intel
Check this link: http://downloadcenter.intel.com/Product_Filter.aspx?lang=eng&ProductID=603
I don't see any drivers for Windows Server 2003, but you can try those Windows 2000 drivers.
