5223 Discussions
Server S5520UR + Windows Server 2012R2 does not work with SSDSC2BA20 disks
I installed Windows Server 2012R2 on my S5520UR platform. But the windows hangs up when I attach an SSD disk.
I'm attaching logs from the sysinfo utility.
Do you have any tip to help me ?
The board you are looking support for has been discontinued and is not longer under support. As an additional recommendation please try with validated hardware since the issue seems to be related to compatibility with the SDD you are using:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006908.html Tested Memory and Hardware List for the Intel® Server Board S5520UR Family
