5241 Discussions
Supports SRIS (Separate Reference Clock With Independent Spread) on S2600WFT R2208WFTZSR platform.
npobaum
Hello.
We were given an external JBOF AIC J2024-04 disk cage for testing and a retimer PCIe board to connect it. The basket and board developers recommended that we enable SRIS support in the BIOS for connection.
At this stage, we changed the riser in the second slot to the A2UL16RISER2 model and installed a retimer card in the 16x port and enabled VMD support in the BIOS of the Intel S2600WFT server on the corresponding riser port.
I attach the JBOF connection diagram to the board in the screenshot.
Tell me if this technology is supported in Intel S2600WFT servers and if supported, how can I enable it?
Sergey F.
SergioS_Intel
Hello cipcp26785,
First, we would like to apologize for the delay on our response.
Upon checking with our higher level support, they have investigated and the Intel® Server Board S2600WFT does not support SRIS (Separate Reference Clock With Independent Spread) technology.
Sergio S.
IntelSupport
Community Manager
Hello sfadeev_npobaum
Thank you for contacting Intel Customer Support.
Please allow us to check on your question and we will contact you as soon as we have an update.
Sergio S.
SergeyLysokobylka
Hello Sergio S.,
Please clarify how long the answer can be awaiting for this issue?
npobaum
this week already JBOF along with PCIe boards will need to be handed over
SergioS_Intel
Hello cipcp26785,
Sergio S.
SergioS_Intel
Hello cipcp26785,
We are following your case and we would like to know if you need further assistance or if we can close this thread.
Sergio S.
