Web Console 2.0 on SBS 2008
I am trying to get the Intel Raid Web Console to work on a MS SBS 2008 server. This is a brand new install. MB is a S5000VSA and RAID controller is the SCRSATAWB. Installation completes successfully but when you open console on server there is no server listed. Also you can't connect if you try and do the remote connection to the server IP address. Does anyone have the configuration mods to allow console to run on the SBS 2008 server?
I have found the solution. Uninstall the Web Console. Reinstall and choose custom. For the installation type choose 'standalone'. Once installation is complete. Go to Programs > Web Console > Startup UI . The logon window should appear. Log on using local admin acct info. Console will open and you can configure alerts etc.
