Hi, I am just wondering if the E7-8880 v4 CPU is compatible with a Supermicro X10DRU-i+ motherboard. I'm struggling to find any info on this. Maybe that's an indication of incompatibility.
Any info would be appreciated.
Hello anthward1972,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Products Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
Hi anthward1972,
Thank you for reaching Intel Community.
Kindly be informed that the Intel® Xeon® Processor E7-8890 v4 has been discontinued and Intel no longer supports it.
Since you have mentioned that the board is from SuperMicro, we kindly advise you to contact the SuperMicro support team for assistance. They will be best equipped to provide support and address any concerns related to their product.
Below is the compatibility board from SuperMicro Web:
Link: https://www.supermicro.com/en/products/motherboards/matrix
Hope this clarifies your concerns.
Fikri O.
Hi anthward1972,
Hope you are doing well.
Since the product you are referring to has reached the End of Interactive Support where Intel no longer provides direct assistance or troubleshooting through interactive channels such as live chat, phone support, or interactive forums.
We will proceed to close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Fikri O.
Determining motherboard compatibility for the Intel Xeon E7-8880v4 processor involves considering several factors:
1. **Socket Compatibility**: The Xeon E7-8880v4 uses the LGA2011-3 socket. Ensure that the motherboard you're considering supports this socket type.
2. **Chipset Compatibility**: Check if the motherboard's chipset is compatible with the Xeon E7-8880v4 processor. It's recommended to use a motherboard with a chipset that officially supports this processor for optimal performance and compatibility.
3. **BIOS Update**: Some motherboards may require a BIOS update to support newer processors like the Xeon E7-8880v4. Ensure that the motherboard manufacturer provides BIOS updates that include compatibility with this processor.
4. **Memory Compatibility**: Verify that the motherboard supports the type, speed, and capacity of DDR4 memory required by the Xeon E7-8880v4 processor.
5. **Form Factor**: Consider the motherboard's form factor (e.g., ATX, E-ATX, etc.) to ensure it fits in your PC case and offers the required expansion slots and features for your needs.
6. **Power Delivery**: The Xeon E7-8880v4 is a high-end processor that requires sufficient power delivery from the motherboard's VRM (Voltage Regulator Module). Ensure that the motherboard's VRM is capable of handling the power demands of this processor.
7. **Manufacturer Compatibility**: Choose a reputable motherboard manufacturer known for producing reliable and compatible products. Research user reviews and compatibility lists to ensure compatibility and reliability.
By considering these factors and conducting thorough research, you can find a compatible motherboard for your Intel Xeon E7-8880v4 processor. If you're uncertain about compatibility, contacting the motherboard manufacturer's support or consulting with PC hardware experts can provide further assistance.
Thanks for your help.
