5240 Discussions
intel 5520UR + Xeon E5620 AES-NI support
АДудк
intel 5520UR + 2*Xeon E5620 как включить поддержку AES-NI?
Я обновил BIOS платы до версии R0066.
В ReleaseNotes_R0069.txt сказано:
R0050
FEATURES ADDED/REMOVED
11,AES-NI support changed to enabled.
как включить поддержку AES-NI ?
Thank you for contacting Intel(R) Technical Support.
I understand that you are looking to enable the feature AES-NI.
According to the information you sent, it shows that the feature is already enable in the BIOS.
Jeremiah A.
АДудк
Спасибо за ответ!
Утилита CPU-z не показывает поддержку AES-NI. И другие приложения не показывают что AES-NI включено.
Hello Andrey,
Thank you for your update.
You will need to check directly into the Server Board BIOS as this tool is not supported by Intel(R).
Jeremiah A.
Hello Andrey,
You can try the https://downloadcenter.intel.com/download/7838/Intel-Processor-Identification-Utility-Windows-Version Intel Processor Identification Utility to verify the feature.
Jeremiah A.
Hello Andrey,
I hope you are doing well today.
I'm following up with you to see if the app helped verify that the feature AES-IN is present in the server board.
Jeremiah A.
Intel(R) Customer Support
АДудк
Добрый день, уважаемая техподдержка!
Спасибо Вам за совет воспользоваться утилитой Intel Processor Identification Utility.
К сожалению она тоже показала отсутствие поддержки технологии AES-NI.
Hello Andrey,
Let check if your current configuration supports this issue. The processor does, but let me confirm if there is a specific configuration to enable it.
Jeremiah A.
Hello Andrey,
I'm checking if your current configuration supports this issue. The processor does, but let me confirm if there is a specific configuration to enable it.
Jeremiah A.
Hi Andrey,
I was not able to find information of the support on AES-NI by Intel(R) 5520UR as this product is end of interactive support.
You can continue to access resources on Intel Support pages for these products, or ask for help from other users through the /community/tech/servers Intel Support Community.
Jeremiah A,
АДудк
Добрый день! Спасибо за техническую поддержку и рекомендации. Посмотрите пожалуйста фото BIOS.
Hello Andrey,
Be aware that this server boars is end of interactive support.
While discontinued products are no longer supported via phone, email, or chat, some self-help options may still be available for your product. These options may include: support content, drivers & software, community forums, and warranty coverage.
Reference the information below to find available support and downloads content. To verify if warranty is still available for your product, https://supporttickets.intel.com/warrantyinfo?lang=en-US check your warranty coverage. Join the discussions by visiting the /community/tech/discontinued-products community forum.
Jeremiah A.
Hi Andrey,
Jeremiah A,
Hi Andrey,
I have not heard back from you in regards to this case.
I will proceed in closing this case.
Jeremiah A.
Intel Technical Support
