5182 Discussions
s2600co - BIOS Recovery not working
ЯДобр
Good afternoon!
I have a problem with starting the server motherboard s2600сo. Using your "Troubleshooting Server Boot Issues" was the answer:
"Some older Intel® Server Boards are not compatible with the Intel® Xeon® Processor E5 V2. See the processor compatibility page listings, select your server board, and confirm that your board is compatible.
Some Intel Server Boards might require a BIOS upgrade before installing an Intel® Xeon® Processor E5 V2. "
I check that my processor Intel Xenon e5-2640v2, included in the list of compatible motherboard s2600so. (link below)
http://www.intel.com/support/motherboards/server/s2600co/sb/CS-033242.htm?wapkw=e5-2643 http://www.intel.com/support/motherboards/server/s2600co/sb/CS-033242.htm?wapkw=e5-2643
Next (on the advice of the above Troubleshooting), I decided to update the BIOS. Found firmware updates here:
https://downloadcenter.intel.com/search?keyword=Intel+Server+Board+s2600со https://downloadcenter.intel.com/search?keyword=Intel+Server+Board+s2600со
Of course I am using the latest firmware. But it did not work . Following the instructions I could not update the BIOS.
What am i doing wrong? Maybe I should someone help?
David_A_Intel
Is the system completing the POST process? I am getting the impression it does but I would like to clarify it.
If so, what kind of error message do you get when attempting the BIOS update?
Now if the issue is that the unit is not completing POST, please provide us with the PBA of the board to determine if the revision of the board would support your processor out of the box.
ЯДобр
To clarify the situation:
Troubleshooting Server Boot Issues (my answers):
1. I am building a system for the first time
2. My front panel has the green standby power LED lit
3. The chassis fans start spinning
4. I do not see anything (display is blank)
5. I do not hear any beeps.
As a result, they gave me a message that I wrote in the message above.
When I tried to update bios - while updating the screen it was empty, and the only thing that gave me the server is 4 beeps signal. Look for information about it, I found that it updates the BIOS error.
I hope I have given a full and correct picture of my problem.
P.S. Thanks for your help and your quick reply!
David_A_Intel
Thank you for the clarification. Can you provide us with the PBA of the board?
ЯДобр
Excuse me, the first time I did not understand what you want of me.
I found a number of PBA on its motherboard, here it is:
PBA G29920-208
If you want, I can take a picture and attach a photo?)
PS Thank you for your answers and your patience!
ЯДобр
Good afternoon!
Are you fine? You can still answer, I solve the problem BIOS updates?
P.S. In any case, thank you for your help and look forward to hearing from you soon!
David_A_Intel
The board revision comes already with BIOS version 01.08.0003 which should support your processor. At this point, you should attempt doing firmware upgrade to version https://downloadcenter.intel.com/download/23156 02.01.0002. You may attempt performing a BIOS recovery process for this. If successful, then you may go to the most recent version https://downloadcenter.intel.com/download/24613/Intel-Server-Board-S2600CO-Firmware-Update-Package-for-Extensible-Firmware-Interface-EFI- 02.04.0003.
If the unit is still unable to POST after the BIOS recovery attempt, I would recommend contacting our http://www.intel.com/p/en_US/support/contactsupport Intel Customer Support team for further assistance on this matter.
ЯДобр
Good afternoon!
Thanks for the answer!
It is strange that the server does not start again BIOS support available CPU ... hope BIOS update will solve the problem. Today definitely try to update the BIOS on the links of your recommendations and accomplish your goal according to the results.
Once again many thanks for the answer, help and spent time on me!
