5181 讨论
s2600cp4 server board make loud noise for cpu fan. I am using other chasis. I have updated the FRUSDR but still fan make too much noise
achow61
初学者
1,777 次查看
I am using Intel Thermal Solution Cooling Fan for E5-2600 Processors BXSTS200C heat sinker for the CPU. Please help.
Amit Prasad Chowrasia
0 项奖励
1 回复
David_A_Intel
主持人
926 次查看
I noticed you mentioned that you chose "Other Chassis" for the FRUSDR selections. Do you actually have a non-Intel chassis? If so, you need to make sure you program each header properly. For instance if you chassis has fans connected to headers 1-2-3; then we need to tell the firmware that we do have fans in those headers; otherwise, this would cause improper readings and would make the fans run at full speed.
I would suggest running the firmware update package again but this select "No" for chassis intrusion regardless of the configuration you have.
0 项奖励
回复
