5175 Discussions
three adapters’ define on HNS7200AP Compute node(what are they use for?)
visirs
Hi,here is my question:
1.the jumper"POWER ALLWAYS PRESENT"​(J323),what it's use for?
2.the jumper“ALL NODE OFF”(J8J2),what it's use for?
3.In the install PDF document,there is an "PSU"controler adapter,what it's pins define?
regards
Visirs​
JoseH_Intel
Hello visirs,
Thank you for joining the community.
We will merge this thread with the following one as per our standard procedure.
https://forums.intel.com/s/question/0D50P00004eVJOz
Jose A.
Intel Customer Support
visirs
Hi,Joka, That's fine.Thanks.And hope you can help me to solve it. with regard Visirs------------------ 原始邮件 ------------------
