Arch Linux Support
paradac
Hi, are there currently any plans to add DPC++ to the Arch repositories, and if not, where can I find the source code to make a PKGBUILD?
RahulV_intel
I will check with the team on this internally and get back to you.
Rahul
Khalik_K_Intel
As far as we are concerned, currently there are no plans to add DPC++ to the Arch repositories.
As you know DPC++ is a part of Intel® oneAPI Base Toolkit, which does not support Arch Linux distributions.
However, users tried to use DPC++ and oneAPI with Arch Linux.
Please, see comments in this thread as they may help you:
https://community.intel.com/t5/Intel-oneAPI-Base-Toolkit/Intel-OneAPI-on-Arch-Linux/td-p/1188296
The ones I would recommend to pay attention to are:
User RN1: "I am using it, although the CPU is not working - I don't know why.
You can install by executing the .bin and then just configuring from bash the setvars.sh, PATH and LD_LIBRARY_PATH."
User siquus: "dpc++ worked out of the box for me on Arch
CPU: i7-1165G7
intel-compute-runtime 20.48.18558-1 (pacman)
l_BaseKit_p_2021.1.0.2659 (intel online installer)
non-sudo install to ~/intel/
. /path/intel/oneapi/setvars.h"
To use DPC++ you will need Intel® oneAPI DPC++/C++ Compiler, which you can get with Intel® oneAPI Base Toolkit.
Please also see Intel Github Project for LLVM technology, which also contains oneAPI DPC++/C++ Compiler.
Hope this helps.
Kind regards,
Khalik.
Khalik_K_Intel
We have not heard back from you.
Has your query been resolved or do you have further question on this?
Khalik.
paradac
Hi Khalik, would it be possible to speak with one of the developers who works on OneAPI? I feel like they might be able to understand some of my questions better.
Khalik_K_Intel
Let me ask which further questions do you have on this and see if we could help?
Khalik.
Khalik_K_Intel
We have not heard from you.
Do you still have any further questions?
Khalik.
Khalik_K_Intel
I have not heard back from you, so I will go ahead and close this thread from my end. Intel will no longer monitor this thread. Feel free to post a new query if you require further assistance from Intel.
Khalik.
