873 Discussions
C++ Compiler Link Problem with Abaqus2023 (2)
LukePark
I've tried everything according to the guide from Vipin_Singh1's message but the situation is the same.
Here's the screenshot.
Is there anything else I can do?
Vipin_S_Intel
Hi Luke, we have sent you a private message. Kindly check your community inbox.
LukePark
Hi Vipin_Singh1, I have sent you a message. Please check the message.
heimiPP
Hi Vipin_Singh1,
I met the same problem. Could you please post the solution here?
Vipin_S_Intel
Vipin_S_Intel
Hi Luke, we would like to inform you that we are routing your query to the dedicated team for further assistance.
LukePark
Hi, Vipin_singh1, thank you very much.
Have a nice day.
Xingwei
Hi Luke, I also had the same issue, would you mind sharing the solution here? Thanks a lot
Sravani_K_Intel
Could you please check the following documentation and see if your Visual Studio version and settings are as expected?
Installing Microsoft Visual Studio* for Use with Intel® Compilers
Intel® Compilers compatibility with Microsoft Visual Studio* and...
Once the above are done, see https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2024-2/specifying-the-location-of-compiler-components.html for how to run setvars.bat by pointing to the desired version of VS.
Sravani_K_Intel
Hi @LukePark Did you get a chance to check this?
