WSL2:intel GPU supported in docker image ?
den6
I built a docker image using the following Dockerfile.
FROM nvcr.io/nvidia/cuda:12.2.0-devel-ubuntu22.04
# Tools
RUN apt-get update && apt-get upgrade -y && \
DEBIAN_FRONTEND=noninteractive apt-get install -y --no-install-recommends \
wget curl ca-certificates gpg-agent software-properties-common && \
rm -rf /var/lib/apt/lists/*
# intel graphics driver
RUN wget -qO - https://repositories.intel.com/gpu/intel-graphics.key | \
gpg --dearmor --output /usr/share/keyrings/intel-graphics.gpg
RUN echo "deb [arch=amd64,i386 signed-by=/usr/share/keyrings/intel-graphics.gpg] https://repositories.intel.com/gpu/ubuntu jammy client" | \
tee /etc/apt/sources.list.d/intel-gpu-jammy.list
#RUN curl -fsSL https://repositories.intel.com/graphics/intel-graphics.key | apt-key add -
#RUN echo "deb [trusted=yes arch=amd64] https://repositories.intel.com/graphics/ubuntu jammy main" > /etc/apt/sources.list.d/intel-graphics.list
RUN apt-get update && apt-get upgrade -y && apt-get install -y \
intel-opencl-icd intel-level-zero-gpu level-zero \
intel-media-va-driver-non-free libmfx1 libmfxgen1 libvpl2 \
libegl-mesa0 libegl1-mesa libegl1-mesa-dev libgbm1 libgl1-mesa-dev libgl1-mesa-dri \
libglapi-mesa libgles2-mesa-dev libglx-mesa0 libigdgmm12 libxatracker2 mesa-va-drivers \
mesa-vdpau-drivers mesa-vulkan-drivers va-driver-all vainfo hwinfo clinfo
RUN apt-get install -y \
libigc-dev intel-igc-cm libigdfcl-dev libigfxcmrt-dev level-zero-dev
# neo
COPY neo.sh /root/
WORKDIR /root
RUN ./neo.sh
# OneAPI base/hpc kit
RUN curl -fsSL https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB | gpg --dearmor | tee /usr/share/keyrings/oneapi-archive-keyring.gpg
RUN echo "deb [signed-by=/usr/share/keyrings/oneapi-archive-keyring.gpg] https://apt.repos.intel.com/oneapi all main" | tee /etc/apt/sources.list.d/oneAPI.list
RUN apt-get --fix-broken install -y
RUN apt-get update && apt-get upgrade -y && apt-get install -y intel-basekit
RUN apt-get update && apt-get upgrade -y && apt-get install -y intel-hpckit
RUN useradd render && gpasswd -a root render
neo.sh is as follows
# neo.sh
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.14828.8/intel-igc-core_1.0.14828.8_amd64.deb
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.14828.8/intel-igc-opencl_1.0.14828.8_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/intel-level-zero-gpu-dbgsym_1.3.26918.9_amd64.ddeb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/intel-level-zero-gpu_1.3.26918.9_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/intel-opencl-icd-dbgsym_23.30.26918.9_amd64.ddeb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/intel-opencl-icd_23.30.26918.9_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/libigdgmm12_22.3.0_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/23.30.26918.9/ww30.sum
sha256sum -c ww30.sum
dpkg -i *.deb
docker run command is as follows
docker run --gpus all --device=/dev/dri -it --rm  $image
Same as this article, sycl-ls does not work in the docker image.
https://community.intel.com/t5/Intel-oneAPI-Base-Toolkit/WSL2-GPU-supported-in-docker-image/m-p/1454995
Any help would be greatly appreciated.
Vipin_S_Intel
Hi Shinji, we are routing your query to the respective team for the further help. They will get back to you as soon as possible.
den6
Thank you for your prompt reply. I look forward to the support team's response.
SeshaP_Intel
Could you kindly provide a screenshot of the output when running the following command in WSL2:
sycl-ls
In order to detect the GPU using sycl-ls in the Docker image, it should be accessible within WSL2. If you haven't installed the oneAPI toolkits yet, please consider installing them in WSL2 before proceeding.
Thanks and Regards,
Pendyala Sesha Srinivas
den6
Screen shot of sycl-ls in WSL2.
This is in Docker.
den6
Sorry I forget to exec "sh oneapi-for-nvidia-gpus-2023.2.1-cuda-12.0-linux.sh”.
After doing that, Nvidia gpu is dtetected.
den6
Does anyone have any advice?
I would be very grateful if you could give me some advice.
SeshaP_Intel
We were able to reproduce the issue.
We are working on it internally. We will get back to you soon.
Thanks and Regards,
den6
Thank you kindly for your progress report !
I look forward to resolving the issue !
Thanks and Regards,
den6
den6
I heard that OneAPI version 2024 has been released, but when I run ’apt list intel-basekit -a’, 2024 is still not displayed.
If I were able to update to 2024, would that solve the problem?
Thanks and Regards,
den6
sebbalint
Hi den6 and dear Intel-Support-Team,
any updates on this matter or does someone know of a viable workaround?
I have been looking forward to using intel gpus in docker with wsl for a while now and have not been successful myself.
With kind regards,
sebbalint
den6
Hi, sebbalint
OneAPI 2024.0 is now installed with apt, so I tried it, but unfortunately there was no change in the situation.
I would appreciate it if you could let me know what you have tried.
Thanks and regards.
den6
den6
Hi everyone !
I succeeded in recognizing the Intel built-in GPU by executing docker run with the following options:
--device /dev/dxg --volume /usr/lib/wsl:/usr/lib/wsl
sycl-ls output:
root@dcb28c3f8794:~/work/OneAPI/codeplay# sycl-ls
[opencl:cpu][opencl:0] Intel(R) OpenCL, 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz OpenCL 3.0 (Build 0) [2024.18.6.0.02_160000]
[opencl:gpu][opencl:1] Intel(R) OpenCL Graphics, Intel(R) Graphics [0x9a49] OpenCL 3.0 NEO  [24.13.29138.29]
[level_zero:gpu][level_zero:0] Intel(R) Level-Zero, Intel(R) Graphics [0x9a49] 1.3 [1.3.29138]
[cuda:gpu][cuda:0] NVIDIA CUDA BACKEND, NVIDIA GeForce MX450 7.5 [CUDA 12.4]
