C++ compiler (2021.3.0) crashes
mborn
I tried icx (2021.3.0) on a code base that compiles just fine with Intel Classic C++ 19.1, MSVC, clang and gcc. A specific file causes it to crash with this error message:
 [1/2] Building CXX object CMakeFiles\solver.dir\solver\dev\asrc\asrcconv.cpp.obj
FAILED: CMakeFiles/solver.dir/solver/dev/asrc/asrcconv.cpp.obj
C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\icx.exe /nologo /TP -DUNICODE -D_CRT_SECURE_NO_WARNINGS -D_LIB -D_UNICODE -D__STDC_WANT_LIB_EXT1__ -IC:\ltspice\ltspice\fmt\fmt.git\include /Qm64 /bigobj /std:c++17 /EHsc /Zc:wchar_t /Zc:inline /Zc:forScope /O3 /Qlong-double /Qpc80 /Zi /O2 /Ob1 /DNDEBUG -MT -QMMD -QMT CMakeFiles\solver.dir\solver\dev\asrc\asrcconv.cpp.obj -QMF CMakeFiles\solver.dir\solver\dev\asrc\asrcconv.cpp.obj.d /FoCMakeFiles\solver.dir\solver\dev\asrc\asrcconv.cpp.obj /FdCMakeFiles\solver.dir\solver.pdb -c C:\ltspice\ltspice\solver\dev\asrc\asrcconv.cpp
C:\ltspice\ltspice\out\build\windows-x64-release-oneapi\EXEC : fatal error : error in backend: Stack empty??
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: C:\\PROGRA~2\\Intel\\oneAPI\\compiler\\latest\\windows\\bin\\clang-cl.exe @C:\\Users\\mborn\\AppData\\Local\\Temp\\171440arg2
1. <eof> parser at end of file
2. Code generation
3. Running pass 'Function Pass Manager' on module 'C:\ltspice\ltspice\solver\dev\asrc\asrcconv.cpp'.
4. Running pass 'X86 FP Stackifier' on function ''
#0 0x00007ffefbc79689 (C:\WINDOWS\System32\KERNELBASE.dll+0x39689)
#1 0x00007ff7ed1a305a (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x5e305a)
#2 0x00007ff7ed1ec9e9 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x62c9e9)
#3 0x00007ff7ecbc7d9e (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x7d9e)
#4 0x00007ff7ed1a348b (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x5e348b)
#5 0x00007ff7ed1a3365 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x5e3365)
#6 0x00007ff7ed63b51c (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0xa7b51c)
#7 0x00007ff7ed638dc1 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0xa78dc1)
#8 0x00007ff7ed613a63 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0xa53a63)
#9 0x00007ff7ecdc91ce (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x2091ce)
#10 0x00007ff7ecdceba3 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x20eba3)
#11 0x00007ff7ecdc9731 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x209731)
#12 0x00007ff7ee3bacab (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x17facab)
#13 0x00007ff7ee77a717 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x1bba717)
#14 0x00007ff7efbb25d5 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x2ff25d5)
#15 0x00007ff7ee775ba8 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x1bb5ba8)
#16 0x00007ff7ee6d072e (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x1b1072e)
#17 0x00007ff7ed4eb54c (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x92b54c)
#18 0x00007ff7ed58d1c6 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x9cd1c6)
#19 0x00007ff7ecbc79ef (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x79ef)
#20 0x00007ff7ecbc56f4 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x56f4)
#21 0x00007ff7ee4b1506 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x18f1506)
#22 0x00007ff7ed1a2ebf (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x5e2ebf)
#23 0x00007ff7ee4b0b10 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x18f0b10)
#24 0x00007ff7ed494eb0 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x8d4eb0)
#25 0x00007ff7ed4953d9 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x8d53d9)
#26 0x00007ff7ed4b3ab7 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x8f3ab7)
#27 0x00007ff7ecbc4f19 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x4f19)
#28 0x00007ff7f0dbd7c8 (C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\clang-cl.exe+0x41fd7c8)
#29 0x00007ffefdf77974 (C:\WINDOWS\System32\KERNEL32.DLL+0x17974)
#30 0x00007ffefed0a2f1 (C:\WINDOWS\SYSTEM32\ntdll.dll+0x5a2f1)
C:\ltspice\ltspice\out\build\windows-x64-release-oneapi\clang-cl : error : clang frontend command failed with exit code 70 (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2021.3.0 (2021.3.0.20210619)
Target: x86_64-pc-windows-msvc
Thread model: posix
InstalledDir: C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin
clang-cl: note: diagnostic msg:
PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
Preprocessed source(s) and associated run script(s) are located at:
clang-cl: note: diagnostic msg: C:\Users\mborn\AppData\Local\Temp\asrcconv-15f153.cpp
clang-cl: note: diagnostic msg: C:\Users\mborn\AppData\Local\Temp\asrcconv-15f153.sh
ninja: build stopped: subcommand failed.
I can't post my source code here, but perhaps Intel is still interested in improving their compiler?
Mathias
Khalik_K_Intel
Hello Mathias,
This issue was fixed in the released Intel oneAPI DPC++/C++ Compiler which is part of oneAPI 2022.1 Base Toolkit.
The toolkit can be downloaded here: https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
I have checked the reproducer from this forum thread with the released compiler and the code compiles successfully on our end.
Khalik.
VidyalathaB_Intel
Yes, definitely we would like to consider your feedback in improving the compilers.
You have a choice to send your source code by private message. So if you are willing to send it, please do let us know, so that we can contact you privately.
Vidya.
mborn
Yes, I would like to give you what you need to fix this.
Mathias
Khalik_K_Intel
Thank you for contacting Intel support.
We were able to reproduce issue on our end.
We have now escalated this issue to a development team.
Have a nice day ahead!
Khalik.
mborn
still crashes with 2021.4.
Mathias
Khalik_K_Intel
The fix is not available in 2021.4.
It should be available in one of the upcoming releases of Intel OneAPI.
Khalik.
Khalik_K_Intel
Hello Mathias,
Khalik.
Khalik_K_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
