CL_DEVICE_NOT_AVAILABLE
WenChung_C_Intel
I am trying to install OneAPI beta on local server. System configuration as below:
Xeon 6130 x2
Mem: 24G RDIMM
OS: Linux S2600WFT 4.15.0-70-generic #79~16.04.1-Ubuntu SMP Tue Nov 12 14:01:10 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
GCC: gcc (Ubuntu 5.4.0-6ubuntu1~16.04.12) 5.4.0 20160609
OpenCL driver: opencl_runtime_16.1.2_x64
Running the vectoradd example, compilation passed, but run the program yield the run time error message as below:
OpenCL API failed. OpenCL API returns: -2 (CL_DEVICE_NOT_AVAILABLE) -2 (CL_DEVICE_NOT_AVAILABLE)
it seemed it can not recognize CPU as OpenCL device, and i don't know which OpenCL driver I should install.
Please advise.
Vincent
Kaleem_A_Intel
Hi Wen Chung,
We are working on this issue and will get back to you.
Kaleem
Varsha_M_Intel
Hi Vincent,
How did you install OpenCL? You do not need to seperately install OpenCL, runtime is part of the oneAPI package. Could you paste your clinfo output here?
-Varsha
WenChung_C_Intel
Thanks for reply.
I did a fresh install on Ubuntu 16.04. then installed OneAPI package. It has CL_DEVICE_NOT_AVAILABLE error so I installed OpenCL runtime from https://software.intel.com/en-us/articles/opencl-drivers , and it is still the same.
clinfo:
vincent@S2600WFT:~/BaseKit-code-samples-master/DPC++Compiler/vector-add$ clinfo
Number of platforms                               3
  Platform Name                                   Intel(R) OpenCL
  Platform Vendor                                 Intel(R) Corporation
  Platform Version                                OpenCL 2.1 LINUX
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             INTEL
  Platform Name                                   Intel(R) CPU Runtime for OpenCL(TM) Applications
  Platform Name                                   Intel(R) FPGA Emulation Platform for OpenCL(TM)
  Platform Version                                OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
  Platform Profile                                EMBEDDED_PROFILE
  Platform Extensions                             cl_khr_icd cl_khr_byte_addressable_store cl_intel_fpga_host_pipe cles_khr_int64 cl_khr_il_program
  Platform Extensions function suffix             IntelFPGA
Number of devices                                 1
  Device Name                                     Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
  Device Vendor                                   Intel(R) Corporation
  Device Vendor ID                                0x8086
  Device Version                                  OpenCL 2.1 (Build 0)
  Driver Version                                  2019.9.9.0
  Device OpenCL C Version                         OpenCL C 2.0
  Device Type                                     CPU
  Device Profile                                  FULL_PROFILE
  Max compute units                               64
  Max clock frequency                             2100MHz
  Device Partition                                (core)
    Max number of sub-devices                     64
    Supported partition types                     by counts, equally, by names (Intel)
  Max work item dimensions                        3
  Max work item sizes                             8192x8192x8192
  Max work group size                             8192
  Preferred work group size multiple              128
  Max sub-groups per work group                   1
  Preferred / native vector sizes
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  No
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
  Address bits                                    64, Little-Endian
  Global memory size                              24911872000 (23.2GiB)
  Error Correction support                        No
  Max memory allocation                           6227968000 (5.8GiB)
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   Yes
    Atomics                                       Yes
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       1024 bits (128 bytes)
  Preferred alignment for atomics
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             65536 (64KiB)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        262144
  Global Memory cache line                        64 bytes
  Image support                                   Yes
    Max number of samplers per kernel             480
    Max size for 1D images from buffer            389248000 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   64 bytes
    Pitch alignment for 2D image buffers          64 bytes
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 480
    Max number of write image args                480
    Max number of read/write image args           480
  Max number of pipe args                         16
  Max active pipe reservations                    4095
  Max pipe packet size                            1024
  Local memory type                               Global
  Local memory size                               32768 (32KiB)
  Max constant buffer size                        131072 (128KiB)
  Max number of constant args                     480
  Max size of kernel argument                     3840 (3.75KiB)
  Queue properties (on host)
    Out-of-order execution                        Yes
    Profiling                                     Yes
    Local thread execution (Intel)                Yes
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                4294967295 (4GiB)
    Max size                                      4294967295 (4GiB)
  Max queues on device                            4294967295
  Max events on device                            4294967295
  Prefer user sync for interop                    No
  Profiling timer resolution                      1ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            Yes
    Sub-group independent forward progress        No
    IL version                                    SPIR-V_1.0
    SPIR versions                                 1.2
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Device Extensions                               cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
Number of devices                                 1
  Device Type                                     CPU
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    Denormals                                     Yes
    Round to zero                                 No
    Denormals                                     Yes
    Round to zero                                 Yes
    Atomics                                       Yes
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Image support                                   Yes
    Profiling                                     Yes
    Profiling                                     Yes
    SPIR versions                                 1.2
  Built-in kernels
Number of devices                                 1
  Device Name                                     Intel(R) FPGA Emulation Device
  Device Vendor ID                                0x1172
  Device Version                                  OpenCL 1.0
  Driver Version                                  2019.8.9.0
  Device OpenCL C Version                         OpenCL C 1.0
  Device Type                                     Accelerator
  Device Profile                                  EMBEDDED_PROFILE
  Max work item sizes                             67108864x67108864x67108864
  Max work group size                             67108864
  Preferred work group size multiple              <getWGsizes:494: create context : error -2>
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (n/a)
    Denormals                                     Yes
    Round to zero                                 No
  Double-precision Floating-point support         (n/a)
  Image support                                   No
  Local memory size                               262144 (256KiB)
  Queue properties
    Profiling                                     Yes
  Device Extensions                               cl_khr_icd cl_khr_byte_addressable_store cl_intel_fpga_host_pipe cles_khr_int64 cl_khr_il_program
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  No platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   No platform
  clCreateContext(NULL, ...) [default]            No platform
  clCreateContext(NULL, ...) [other]              Success [INTEL]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
Varsha_M_Intel
Hi Vincent,
Could you please uninstall the OpenCL runtime  and then run clinfo?
Did you run the oneAPI installer with sudo privileges?
-Varsha
WenChung_C_Intel
Hi Varsha,
yes, I did use root privilege to install.
Please check the new clinfo below: (now the number of platforms become 2 but still can not run)
Number of platforms                               2
Number of devices                                 1
  Device Type                                     CPU
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    Denormals                                     Yes
    Round to zero                                 No
    Denormals                                     Yes
    Round to zero                                 Yes
    Atomics                                       Yes
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Image support                                   Yes
    Profiling                                     Yes
    Profiling                                     Yes
    SPIR versions                                 1.2
  Built-in kernels
Number of devices                                 1
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (n/a)
    Denormals                                     Yes
    Round to zero                                 No
  Image support                                   No
  Queue properties
    Profiling                                     Yes
Varsha_M_Intel
Hi Vincent,
This is strange. Also, did you source the oneAPI env or dpcpp env?
Varsha
WenChung_C_Intel
Hi Varsha,
I use "source setvars.sh" for the environment.
Further, I used strace to check and it seemed the program couldn't find OpenCL library. is there any environment variables I have to set?
thanks
trace.txt
execve("./vector-add.exe", ["./vector-add.exe"], [/* 76 vars */]) = 0
brk(NULL)                               = 0x767000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb5a2700000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/opt/intel/inteloneapi/vpl/latest/lib/tls/x86_64/libOpenCL.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/opt/intel/inteloneapi/vpl/latest/lib/tls/x86_64", 0x7ffe7717ac20) = -1 ENOENT (No such file or directory)
open("/opt/intel/inteloneapi/vpl/latest/lib/tls/libOpenCL.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/opt/intel/inteloneapi/vpl/latest/lib/tls", 0x7ffe7717ac20) = -1 ENOENT (No such file or directory)
open("/opt/intel/inteloneapi/vpl/latest/lib/x86_64/libOpenCL.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/opt/intel/inteloneapi/vpl/latest/lib/x86_64", 0x7ffe7717ac20) = -1 ENOENT (No such file or directory)
open("/opt/intel/inteloneapi/vpl/latest/lib/libOpenCL.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/opt/intel/inteloneapi/vpl/latest/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
WenChung_C_Intel
I got it running by re-installing the ubuntu 18.04. the compiler/runtime all working.
Please take sometime to check 16.04 to see if any package is missing.
Vincent
MaheshB_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards,
-Mahesh
