806 Discussions
Cannot create DLL which offloads part of the code to Intel Xe GPU
dtroncho
I have a DLL comprised of 3 cpp files. I have separated the "offloadable" (basically matrix multiplications) code into one of those 3 files.
I have downloaded & installed the latest version of the Intel OneAPI HPC Toolkit.
If I try to compile & link all them into a DLL with this command (executed in the Intel OneAPI Command Prompt for Intel64 for Visual Studio 2022):
icx /LD /out:MatMul.dll DLLMAIN.CPP MAIN.CPP OFFLOADABLE.CPP /c /nologo /Qiopenmp /Qopenmp-targets=spir64
I obtain:
clang-cl: error: The use of '-LD' is not supported with '/Qiopenmp /Qopenmp-targets=spir64'.
If I compile these 3 files separatedly, with these commands (same console):
icx DLLMAIN.CPP /c /nologo /Qiopenmp
icx MAIN.CPP /c /Qiopenmp
icx OFFLOADABLE.CPP /c /nologo /Qiopenmp /Qopenmp-targets=spir64
It creates the corresponding .obj correctly, but when I try to compile them with a source.def file which defines what this DLL must export, with:
icx MAIN.OBJ DLLMAIN.OBJ OFFLOADABLE.OBJ /LD -o MatMul.dll /DEF:source.def /Qiopenmp /Qopenmp-targets=spir64
Response is:
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2022.1.0 Build 20220316
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
a-3292ef.obj : warning LNK4078: multiple '__CLANG_OFFLOAD_BUNDLE__openmp-s' sections found with different attributes (40500040)
And it creates the DLL, but when I try to use it from a .NET program which has a declaration to use one of its methods, an error pops-up saying:
"Error in MyInitialize: Unable to load DLL 'MatMul.dll' or one of its dependencies: The specified module could not be found. (0x8007007E).
Can you please help me? If I could solve this, then parts of DLLs could be also off-loaded to Intel's hardware opening lots of possibilities for businesses.
I look forward to your help, thanks in advance.
David.
Anoop_M_Intel
The fix is available in 2024.0 compiler. Please feel free to download the latest compiler from Intel Registration Center.
dtroncho
Thank you for informing. I will asap.
