Compiler Errors (Emit wrong registers)
hyungseok
I discovered that the latest x86-64 ICX 2024.0.0 generates incorrect registers.
This error has been identified in 15 opcodes.
Buggy code.
void bug(int num) {
__asm__( ".intel_syntax noprefix\n"
"nop\n"
"cmpbexadd [RAX+1], EBP, R9D\n"
"cmpbxadd [RAX+1], EBP, R9D\n"
"cmplexadd [RAX+1], EBP, R9D\n"
"cmplxadd [RAX+1], EBP, R9D\n"
"cmpnbexadd [RAX+1], EBP, R9D\n"
"cmpnbxadd [RAX+1], EBP, R9D\n"
"cmpnlxadd [RAX+1], EBP, R9D\n"
"cmpnoxadd [RAX+1], EBP, R9D\n"
"cmpnpxadd [RAX+1], EBP, R9D\n"
"cmpnsxadd [RAX+1], EBP, R9D\n"
"cmpnzxadd [RAX+1], EBP, R9D\n"
"cmppxadd [RAX+1], EBP, R9D\n"
"cmpsxadd [RAX+1], EBP, R9D\n"
"cmpzxadd [RAX+1], EBP, R9D\n"
"nop\n"
Compiled Code
bug:
push rbp
mov rbp,rsp
mov DWORD PTR [rbp-0x4],edi
nop
cmpbexadd DWORD PTR [rax+0x1],r13d,r9d
cmpbxadd DWORD PTR [rax+0x1],r13d,r9d
cmplexadd DWORD PTR [rax+0x1],r13d,r9d
cmplxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnbexadd DWORD PTR [rax+0x1],r13d,r9d
cmpnbxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnlxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnoxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnpxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnsxadd DWORD PTR [rax+0x1],r13d,r9d
cmpnzxadd DWORD PTR [rax+0x1],r13d,r9d
cmppxadd DWORD PTR [rax+0x1],r13d,r9d
cmpsxadd DWORD PTR [rax+0x1],r13d,r9d
cmpzxadd DWORD PTR [rax+0x1],r13d,r9d
nop
pop rbp
ret
I tested it through godbolt.
https://godbolt.org/z/1hrhMWY39
Alex_Y_Intel
I've escalated your case to our internal engineering team.
Alex_Y_Intel
The fix is expected be in compiler version 2025.0 release.
