884 Discussions
Compiler errors occurs when emitting 32bit binaries
hyungseok
I discovered that the latest x86-64 ICX 2024.0.0 emits invalid registers when it generates x86 binaries.
This error has been identified in 2 opcodes.
Buggy code.
void bug(int num) {
__asm__(
".intel_syntax noprefix\n"
"enqcmd SP, ZMMWORD PTR [EAX]\n"
"enqcmds SP, ZMMWORD PTR [EAX]\n"
Compile Option: -m32
Compiled code
bug:
push ebp
mov ebp,esp
mov eax,DWORD PTR [ebp+0x8]
enqcmd sp,[bx+si]
enqcmds sp,[bx+si]
pop ebp
ret
I tested it through godbolt.
https://godbolt.org/z/TqEKnrTYj
Alex_Y_Intel
Your question has been escalated to our internal team.
Alex_Y_Intel
2024.2 compiler will soon be released, please try it with the newer compiler.
Alex_Y_Intel
The issues had been fixed in 2024.2.
"SP" in the original reproducer should be changed to "ESP" to be able to compile successfully with compiler 2024.2:
repro.c
void bug(int num)
__asm__(
"enqcmd ESP, ZMMWORD PTR [EAX]\n"
"enqcmds ESP, ZMMWORD PTR [EAX]\n"
icx -m32 repro.c -S
Assembly output:
.text
.file "repro.c"
.globl bug # -- Begin function bug
.p2align 4, 0x90
.type bug,@function
bug: #
.cfi_startproc
# %bb.0:
#APP
enqcmd (%eax), %esp
enqcmds (%eax), %esp
#NO_APP
retl
.Lfunc_end0:
.size bug, .Lfunc_end0-bug
.cfi_endproc
# -- End function
.ident "Intel(R) oneAPI DPC++/C++ Compiler 2024.2.0 (2024.2.0.20240602)"
.section ".note.GNU-stack","",@progbits
Alex_Y_Intel
Please also note that 32-bit support has been deprecated.
