Compiling OpenCL program with oneAPI
matthias11
Dear all,
I cannot get the following program to compile with oneAPI (from command line). I use icpx -fsycl vectorAdd.cpp -o vectorAdd.exe. No matter what I try (CL/opencl.hpp)
I always get error messages. How can this be done?
vectorAdd.cpp code is shown below.
Many thanks and best wishes,
Matthias
vectorAdd.cpp:
#include <OpenCL/opencl.hpp>
#include <iostream>
#include <cassert>
#include <numeric>
int main() {
std::vector<cl::Platform> platforms;
cl::Platform::get(&platforms);
assert(platforms.size() > 0);
auto platform = platforms.front();
std::vector<cl::Device> devices;
platforms.front().getDevices(CL_DEVICE_TYPE_GPU, &devices);
assert(devices.size() > 0);
auto device = devices.front();
auto vendor = device.getInfo<CL_DEVICE_VENDOR>();
auto version = device.getInfo<CL_DEVICE_VERSION>();
std::cout << "Device Vendor: " << vendor << std::endl;
std::cout << "Device Version: " << version << std::endl;
cl::Context context(device);
cl::Program::Sources sources;
std::string kernelCode =
" void kernel squareArray(global int* input, global int* output) {"
" size_t gid = get_global_id(0);"
" output[gid] = input[gid] * input[gid];"
sources.push_back({kernelCode.c_str(), kernelCode.length()});
cl_int exitcode = 0;
cl::Program program(context, sources, &exitcode);
program.build();
assert(exitcode == CL_SUCCESS);
cl::Kernel kernel(program, "squareArray", &exitcode);
auto workGroupSize = kernel.getWorkGroupInfo<CL_KERNEL_WORK_GROUP_SIZE>(device);
std::cout << "Kernel Work Group Size: " << workGroupSize << std::endl;
std::vector<int> outVec(1024);
std::vector<int> inVec(1024);
std::iota(inVec.begin(), inVec.end(), 1);
cl::Buffer inBuf(context,
CL_MEM_READ_ONLY | CL_MEM_HOST_NO_ACCESS | CL_MEM_COPY_HOST_PTR,
sizeof(int) * inVec.size(),
inVec.data());
cl::Buffer outBuf(context,
CL_MEM_WRITE_ONLY | CL_MEM_HOST_READ_ONLY,
sizeof(int) * outVec.size());
kernel.setArg(0, inBuf);
kernel.setArg(1, outBuf);
cl::CommandQueue queue(context, device);
queue.enqueueNDRangeKernel(kernel, cl::NullRange, cl::NDRange(inVec.size()));
queue.enqueueReadBuffer(outBuf, CL_TRUE, 0, sizeof(int) * outVec.size(), outVec.data());
for (std::vector<int>::const_iterator i = outVec.begin(); i != outVec.end(); ++i)
std::cout << *i << std::endl;
return 0;
Alex_Y_Intel
Can you please try this simple case:
#include <CL/cl.hpp>
#include <iostream>
#include <vector>
int main() {
return 0;
and let us know which compiler you can compile it successfully?
matthias11
Hi all,
from the short test program you sent me I get CL/cl.hpp not found error.
Where can I get this file from and where is it supposed to be? I've upgraded to the latest oneAPI (August 2024).
Matthias
Alex_Y_Intel
Download OpenCL directory from here: https://github.com/ProjectPhysX/OpenCL-Wrapper/tree/master/src/ and store it in the same directory of your vectorAdd.cpp
Change your #include <OpenCL/opencl.hpp> to #include <CL/cl.hpp>
And do this: icpx vectorAdd.cpp -I./OpenCL/include -L./OpenCL/lib -lOpenCL
