802 Discussions
Crash in Wolfram Mathematica 14.1 prompted contacting Intel
leoHD
After successful installation from the .sh file, Wolfram Mathematica (Linux 14.1 (web documentation version)) crashes and outputs the following:
leo@penguin:/usr/local/Wolfram/Wolfram/14.1/Executables$ ./WolframNB
OMP: Error #13: Assertion failure at kmp_affinity.cpp(644).
OMP: Hint Please submit a bug report with this message, compile and run commands used, and machine configuration info including native compiler and operating system versions. Faster response will be obtained by including all program sources. For information on submitting this issue, please see http://www.intel.com/software/products/support/.
This issue was communicated to Wolfram support, but they professed that it was not their issue due to this issue "not being on their end". I also have submitted this bug to Google, to no avail. This is a supported environment (Debian Linux) being virtualized on ChromeOS. Information regarding the system you can find below:
Virtual system:
OS: Debian GNU/Linux 12 (bookworm) x86_64
Host: crosvm
Kernel: 6.6.50-05083-g5a8e7e69b744
CPU: AMD Ryzen 3 3250C 15W with Radeon Graphics (4)
GPU: 00:02.0 Red Hat, Inc. Virtio 1.0 GPU
 ChromeOS system:
Google Chrome	130.0.6723.101 (Official Build) (64-bit)
Revision	73ae6c8a1aba21e67dd04e1f6a905abe8f441ac9-refs/branch-heads/6723@{#1733}
Platform	16033.51.0 (Official Build) stable-channel zork
Firmware Version	Google_Morphius.13434.356.0
Customization ID	morphius
ARC	12498047 SDK Version: 33
JavaScript	V8 13.0.245.18
Thank you for your help, I am pretty sure this is the right area for this issue.
Viet_H_Intel
We would need to know which compiler version is being used, command line options and a test case to reproduce the error to investigate.
