DPCPP Generates bswap.i64
Michoumichmich
When compiling the following byte swap (with x a 64 bit unsigned):
   ((x & 0xff00000000000000ULL) >> 56)
| ((x & 0x00ff000000000000ULL) >> 40)
| ((x & 0x0000ff0000000000ULL) >> 24)
| ((x & 0x000000ff00000000ULL) >> 8
| ((x & 0x0000000000ff0000ULL) << 24)
| ((x & 0x000000000000ff00ULL) << 40)
| ((x & 0x00000000000000ffULL) << 56);
 DPCPP (llvm-spirv) fails with:
InvalidFunctionCall: Unexpected llvm intrinsic:
llvm.bswap.i64
The version of DPCPP is  2022.0.0 (2022.0.0.20211123). It happens when compiling SYCL kernels for spir64 as well as when I use AOT.
The upstream version of the open source oneAPI compiles the code fine.
To use Intel(R) oneAPI you can "defeat" the optimiser by replacing the `|` by `+` (which is still correct as the bits do not overlap) and it compiles (but is not optimal haha) .
Best,
Michel
Viet_H_Intel
Thank you for reporting this problem to us. This is a known issue and will be fixed in the next update.
Can we close this thread for now?
Regards.
HemanthCH_Intel
Could you please provide the sample reproducer code and steps to reproduce the issue at our end?
Thanks & Regards,
Hemanth.
Michoumichmich
You may compile the following:
#include <CL/sycl.hpp>
static inline uint64_t bswap(uint64_t x){
return
| ((x & 0x000000ff00000000ULL) >> 8 )
int main(){
sycl::queue q{};
auto ptr = sycl::malloc_device<uint64_t>(1, q);
q.single_task([=](){
*ptr = bswap(*ptr);
}).wait();
With the flags `dpcpp -fsycl -O3`. On Intel(R) DevCloud it crashes with the error I mentioned previously too.
Michel
HemanthCH_Intel
We are able to able to reproduce your issue at our end and working on this internally. We will get back to you soon.
Thanks & Regards,
Hemanth.
Viet_H_Intel
Regards.
Viet_H_Intel
Thanks for accepting this as a solution. This thread is now closed and won't be monitored by Intel. If you need anything else, please create a new thread.
Michoumichmich
Okay, thanks for looking into this and have a nice day!
Best,
