887 Discussions
DPCPP-SYCL cannot find GPU target from Python (Pybind11)
Jonas5
I have a simple Pybind11-binding:
#include <CL/sycl.hpp>
#include <pybind11/pybind11.h>
int foo(int a)
sycl::queue q(sycl::gpu_selector_v);
sycl::buffer<int, 1> b(&a, sycl::range<1>(1));
q.submit([&](sycl::handler& cgh){
auto acc = b.get_access<sycl::access::mode::read_write>(cgh);
cgh.single_task<class foo>([=](){
acc[0] +=1;
//accessor
auto acc = b.get_access<sycl::access::mode::read>();
return acc[0];
PYBIND11_MODULE(test_binder, m) {
m.def("foo", &foo);
And a simple script to invoke:
import sys
binder_path = "..."
sys.path.append(binder_path)
from test_binder import *
print(foo(1))
The binder is built in a oneapi-sourced environment, and linked with:
-fsycl -sycl-std=2020 -std=c++20 -fsycl-unnamed-lambda -fPIC
(Cpp-executables built with the same flags are able to execute fine on the GPU.)
When running the `.py` script in the sourced environment, it works fine on the CPU. However, when openCL-devices are forced:
export ONEAPI_DEVICE_SELECTOR=opencl:*
I get the following error:
Traceback (most recent call last):
File "...py", line 8, in <module>
print(foo(1))
RuntimeError: No device of requested type available. Please check https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-dpcpp-system-requirements.html -1 (PI_ERROR_DEVICE_NOT_FOUND)
Is it possible to keep the OpenCL-device exposed through the compiled Python-binder?
(AOT-compiling with -fsycl-targets did not resolve the issue)
NoorjahanSk_Intel
Could you please provide the detailed steps you have followed to build your code?
Also please provide the below details:
OS & Hardware details
The compiler version being used
Could you please let us know why you are using OpenCL devices?
Also please try with a level_zero device and let us know if you observe the same issue.
ONEAPI_DEVICE_SELECTOR=level_zero:gpu
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
As you want to close this thread as mentioned in internal notes, we are going ahead and closing this issue.
Thanks & Regards,
Noorjahan.
