872 Discussions
use of undeclared identifier 'cl' error in example set
mnt
I have followed openmp_reduction example to test host/gpu execution. However, the following commands don't produce the binary file because of the compilation error.
u187665@login-2:build$ qsub  -I  -l nodes=1:gpu:ppn=2 -d .
qsub: waiting for job 2248101.v-qsvr-1.aidevcloud to start
qsub: job 2248101.v-qsvr-1.aidevcloud ready
#      Date:           Sun 12 Mar 2023 10:50:48 AM PDT
#    Job ID:           2248101.v-qsvr-1.aidevcloud
#      User:           u187665
# Resources:           cput=75:00:00,neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
u187665@s019-n008:build$ pwd
/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build
u187665@s019-n008:build$ ls
u187665@s019-n008:build$ cmake ..
-- Default CMAKE_BUILD_TYPE not set using Release
-- The CXX compiler identification is Clang 16.0.0
-- Check for working CXX compiler: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx
-- Check for working CXX compiler: /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build
u187665@s019-n008:build$ make VERBOSE=1
/usr/bin/cmake -S/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction -B/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/CMakeFiles /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory '/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build'
make -f src/CMakeFiles/openmp_reduction.dir/build.make src/CMakeFiles/openmp_reduction.dir/depend
make[2]: Entering directory '/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build'
cd /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/src /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src/CMakeFiles/openmp_reduction.dir/DependInfo.cmake --color=
Dependee "/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src/CMakeFiles/openmp_reduction.dir/DependInfo.cmake" is newer than depender "/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src/CMakeFiles/openmp_reduction.dir/depend.internal".
Dependee "/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src/CMakeFiles/CMakeDirectoryInformation.cmake" is newer than depender "/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src/CMakeFiles/openmp_reduction.dir/depend.internal".
Scanning dependencies of target openmp_reduction
make[2]: Leaving directory '/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build'
make -f src/CMakeFiles/openmp_reduction.dir/build.make src/CMakeFiles/openmp_reduction.dir/build
[ 50%] Building CXX object src/CMakeFiles/openmp_reduction.dir/main.cpp.o
cd /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build/src && /glob/development-tools/versions/oneapi/2023.0.1/oneapi/compiler/2023.0.0/linux/bin/icpx    -fiopenmp -fopenmp-targets=spir64 -fsycl -O3 -DNDEBUG   -o CMakeFiles/openmp_reduction.dir/main.cpp.o -c /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/src/main.cpp
In file included from /home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/src/main.cpp:11:
/glob/development-tools/versions/oneapi/2023.0.1/oneapi/dev-utilities/2021.8.0/include/dpc_common.hpp:14:36: error: use of undeclared identifier 'cl'
static auto exception_handler = [](cl::sycl::exception_list eList) {
1 error generated.
make[2]: *** [src/CMakeFiles/openmp_reduction.dir/build.make:63: src/CMakeFiles/openmp_reduction.dir/main.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:122: src/CMakeFiles/openmp_reduction.dir/all] Error 2
make[1]: Leaving directory '/home/u187665/oneAPI-samples/DirectProgramming/C++/ParallelPatterns/openmp_reduction/build'
make: *** [Makefile:84: all] Error 2
I also tried `nodes=1:xeon:ppn=2` but got the same error.
How can I fix that?
NoorjahanSk_Intel
We request you to try the sample code on another machine with the below changes as the cl namespace is removed from sycl/sycl.hpp header
As Intel DevCloud is a shared environment that comes with pre-installed validated Intel oneAPI software and complimentary packages, user's don't have admin privileges in DevCloud to make changes.
Replace this line
with
static auto exception_handler = [](sycl::exception_list eList)
in dpc_common.hpp , then you will not observe any issues.
Please refer to the below link for more details:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-dpc-c-compiler-release-notes.html
We tried this at our end on some other machine(Ubuntu 20.04) with these changes and it worked as expected.
Please refer to the below screenshot for more details:
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Replace this line
with
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Hi.
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
mnt
I wasn't able to setup the example on my own host due to infrastructure limitations. Therefore, I am not able to test that.
However, as you showed a screen shot that the modifications works, I will accept that as an answer. Maybe it helps someone in the future.
NoorjahanSk_Intel
Thanks for accepting our solution.
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question
Thanks & Regards,
Noorjahan.
