Trouble compiling MFC code
D_F
I'm having trouble compiling MFC code using Intel OneAPI DPC C++ compiler. I get multiple build errors. Attached is a sample MFC project that shows the build errors, I get different errors using the Intel Classic c++ compiler.  Typical errors are "non-static member function without an object argument". Seems to be a redefinition of some MFC defines??
NoorjahanSk_Intel
You can remove these errors by defining a member function with the class object that it belongs to.
For example, we have made the below changes in PropertiesWnd.cpp file
      ON_UPDATE_COMMAND_UI(ID_EXPAND_ALL, &CPropertiesWnd::OnUpdateExpandAllProperties)
      ON_COMMAND(ID_SORTPROPERTIES, &CPropertiesWnd::OnSortProperties)....
Please refer to the below screenshot for more details:
Please try to make similar changes in your application as mentioned above and let us know If your issue still persists.
Thanks & Regards,
Noorjahan.
D_F
Thanks, that did it. However I'm getting a few warnings (-Wunused-local-typedef ). How do I suppress these warnings with the Intel compiler?
NoorjahanSk_Intel
>>Thanks, that did it
Glad to know that it worked for you
You can suppress this warning by adding the/Wno-unused-local-typedef flag under
Properties -> C/C++ -> Command-line -> Additional-options.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Has the information provided above helped? If yes, Could you please confirm whether we can close this thread from our end?
Thanks & Regards,
Noorjahan.
D_F
Yes, thanks for the help.
NoorjahanSk_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question
Thanks & Regards,
Noorjahan.
