835 ディスカッション
DPL 2021.7.0 env script cause environment-modules module load fail
Quanm
ビギナー
2,242件の閲覧回数
RHEL 9.0, Installed l_BaseKit_p_2022.2.0.262_offline.sh.
Create a modulefile oneapi2022
#%Module
module-whatis "Intel oneAPI 2022"
conflict intel/oneapi
source-sh bash /opt/intel/oneapi/2022/setvars.sh
then run
module load oneapi2022
I get a error
-bash: syntax error near unexpected token `done'
If I comment the function rreadlink() in file /opt/intel/oneapi/2022/dpl/2021.7.0/env/vars.sh.
The problem disappeared.
So, what caused this problem, the function rreadlink() or environment-modules?
0 件の賞賛
5 返答(返信)
HemanthCH_Intel
モデレーター
2,216件の閲覧回数
Thanks for posting in Intel communities.
Unfortunately, RHEL 9 is not supported by Intel oneAPI Base Toolkit. Could you please refer to the below link to find the supported OS of the Intel oneAPI Base Toolkit:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-base-toolkit-system-requirements.html
Could you please try with any one of the supported OS?
Thanks & Regards,
Hemanth
HemanthCH_Intel
モデレーター
2,193件の閲覧回数
We haven't heard back from you. Could you please provide any updates on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
モデレーター
2,177件の閲覧回数
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
jangmys
ビギナー
1,839件の閲覧回数
Arrived here by searching for the same error (with oneapi 2021 and 2024). The problem seems to come from the environment-modules source-sh and sh-to-mod tools.
Generating modulefile with
module sh-to-mod bash /share/compilers/intel/2021/setvars.sh > oneapi/2021.0
then loading the module gives
Editing the rreadlink() function in the modulefile as follows
275c275
<         \unset -f command
>         \unset -f command;
281c281
<             return 1
>             return 1;
solves the problem. Same for 2024.0 (different line numbers)
The original rreadcheck() function from Intel's script has the missing semicolons, so I guess it's a bug in environment-modules.
xdelaruelle
ビギナー
1,796件の閲覧回数
This environment-modules issue has been fixed in version 5.1.0.
environment-modules 5.3.0 is now available on RHEL 9. Updating environment-modules will fix your issue.
Xavier
返信
