879 Discussions
Difference in using DPC++ compiler from base toolkit and using the compiler form HPC tool kit?
student4
I see that intel oneAPI DPC++ compiler is provided in both intel oneAPI basetoolkit and HPC toolkit. I would like to know what is the difference in using DPC++ compiler from base toolkit and using the compiler form HPC tool kit?
Thank you.
NoorjahanSk_Intel
There is no difference in using DPC++ compiler from both toolkits.
you can get the compiler in any of these toolkits:
Intel® oneAPI Base Toolkit
Intel® oneAPI HPC Toolkit
Intel® oneAPI IoT Toolkit
You can use DPC++ compiler from any of the above toolkit to build your source code.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
student4
Thanks for the clarification.
NoorjahanSk_Intel
Thank you for accepting our solution.
As this issue has been resolved, we will no longer respond to this thread.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards.
Noorjahan.
