887 Discussions
Unable to declare vector inside SYCL_EXTERNAL function
student4
I have a Main file containing Main.cpp
and Library.dll file containing the following
Sample1.h and Sample1.cpp
Sample2.h and Sample2.cpp
The Main.cpp invokes the Library.dll.
Main.cpp
#include <CL/sycl.hpp>
#include <vector>
#include <iostream>
#include <ext/intel/fpga_extensions.hpp>
#include<complex>
#include "../Library/Sample1.h"
#include "../Library/Sample2.h"
void test()
sycl::ext::intel::fpga_emulator_selector d_selector;
sycl::queue q(d_selector);
Sample1 obj1;
obj1.func1(q);
// Demonstrate vector add both in sequential on CPU and in parallel on device.
int main(int argc, char* argv[]) {
test();
return 0;
Sample1.h
#pragma once
#include <vector>
#include <iostream>
#include<complex>
class _declspec(dllexport)Sample1
public:
Sample1();
~Sample1();
void func1(sycl::queue& q);
Sample1.cpp
#include "Sample1.h"
#include "Sample2.h"
Sample1::Sample1()
Sample1::~Sample1()
void Sample1::func1(sycl::queue& q)
try
q.submit([&](sycl::handler& h)
h.parallel_for(sycl::range{ 4, 2 }, [=](sycl::id<2> idx) {
Sample2 obj;
obj.func2();
q.wait_and_throw();
catch (sycl::exception const& e)
std::cout << "Caught a SYCL host exception:\n" << e.what() << "\n";
Sample2.h
#pragma once
#include <vector>
#include <iostream>
#include<complex>
class _declspec(dllexport)Sample2
public:
SYCL_EXTERNAL Sample2();
SYCL_EXTERNAL ~Sample2();
SYCL_EXTERNAL float func2();
Sample2.cpp
Sample2::Sample2()
Sample2::~Sample2()
float Sample2::func2()
std::vector<std::complex<float>>S(3);
return 0.1f;
I have declared the complex float vector S. When I build this program, it throws an erro showing: SYCL kernel cannot call an undefined function without SYCL_EXTERNAL attribute
I would appreciate your help on this problem.
Thank you.
HemanthCH_Intel
From the above sample reproducer code, please remove the vector declaration from "float Sample2::func2()" function, because the vector allocates memory dynamically which is not supported inside the kernel.
For more information, please refer to this link:https://link.springer.com/content/pdf/10.1007%2F978-1-4842-5574-2.pdf  DataParallel C++ book[page no:14]
Thanks & Regards,
Hemanth.
HemanthCH_Intel
Thanks & Regards,
Hemanth.
student4
Thanks for the clarification.
HemanthCH_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth.
