888 Discussions
Error in documentation about "Getting started instructions" on Windows
tdechaize
On Windows systems (for me W11 Family 64bit), after read informations about "Getting started instructions" , I note wrong instruction in liaison with use of VS2022INSTALLDIR environment variable.
Here the text proposed into your documentation :
"Or, if you have installed the Visual Studio 2022 Build Tools into their standard location you must set VS2022INSTALLDIR to point to that install location. For example, using setvars.bat:
> set "VS2022INSTALLDIR=%ProgramFiles(x86)%\Microsoft Visual Studio\2022\BuildTools"
> "%ProgramFiles(x86)%\Intel\oneAPI\setvars.bat"
VS2022 is not installed by default on "C:\Program Files (x86)" but here "C:\Program Files", and directory "BuildTools" don't exist on "...\Misrosoft Visual Studio\2022".
What is the correct syntax for this environment variable VS2022INSTALLDIR ?
Thank's.
Regards.
TDE
