803 Discussions
Runtime problem on XIOS with oneAPI icx compiler version 2022.2.0+
paolo-oliveri
Dear Intel community experts,
I am trying to run XIOS code from IPSL France:
https://forge.ipsl.jussieu.fr/ioserver
by using oneAPI toolkit.
The software is mainly written in C++, but it's commonly used through its C-Fortran interface, threrefore needing for both Fortran and C++ compilers.
XIOS actually compiles successfully with both Classic and LLVM compilers, while it presents runtime problems with oneAPI version >= 2022.2.0, by using ICPX as C++ compiler and more than a certain number of mpi threads.
Please note that:
   1) previous versions are not affected by this issue
    2) XIOS works correctly with icc+ifort and icc+ifx
Specifically, the xios_server.exe executable gives
free(): invalid pointer
before server.cpp call to
xios_close_context_definition
While debugging, I discovered that the error was not thrown always in the same part of code. Then I proceeded to compile the more simpler test case test_client.exe but I encountered another abnormal termination, again before call to xios_close_context_definition:
malloc(): invalid size (unsorted)
or
malloc(): unaligned fastbin chunk detected 3
malloc(): memory corruption (fast)
malloc(): unaligned tcache chunk detected
depending on the C++ compiler version.
This error can be mitigated by disabling functions inlining at compile time, with the following option
-fno-inline-functions
However, it would be useful to fix the potential bug in the compiler rather than disabling inlining.
After a deep search on the web, I found a discussion possibly related to the same issue
https://fortran-lang.discourse.group/t/c-pointer-not-nullified-using-intel-oneapi-fortran/7518
In this case the problem is the nullification of C pointers using Fortran interface that seems not to work.
Thank you!
