855 Discussions
Example compiles and runs with C++ 2021.7.0 and aborts with DPC++ 2022.2.0
Ian_Chivers
I have a couple of C++ 11 <array> examples that compile and run successfully with the Intel classic C++ compiler (2021.7.0) on Windows, and compile and terminate without generating any output using DPC++  2022.2.0.
Has anyone else had problems moving their C++ code to use the new DPC++ compiler with the <array> class?
I can't attach all of the source files, I get the following error
The attachment's ch3802.cpp content type (text/plain) does not match its file extension and has been removed.
Ian_Chivers
Thanks very much this resolves the issue.
MWind2
New Contributor III
I tried the print_time.cpp with no problems, and re-reading post I realize I need the array use?
Ian_Chivers
Apologies for the incomplete post. It looks like a stack problem on Windows. This is the classic compile command.
icl /EHsc /nologo /F0xffffffff /O2 /Qstd=c++20 ch3802.cxx -o ch3802_intel_classic.exe
and this generates an executable that runs.
Here is the output.
C:\document\cpp\examples>ch3802_intel_classic.exe
Program starts : 0.000002
C++ 11 <array>
134217728
1073741824 bytes
Random numbers : 0.781101
STL sort - <array> : 13.513962
Total time : 14.298434
Here is the dp c++ compiler command line, with messages.
C:\document\cpp\examples>icx /EHsc /nologo /F 0xffffffff /O2 /Qstd=c++20 ch3802.cxx -o ch3802_intel_new.exe
icx: warning: argument unused during compilation: '-F 0xffffffff' [-Wunused-command-line-argument]
C:\document\cpp\examples>ch3802_intel_new.exe
No output or error message.
Here are the required files. I can't attach them.
timer.cpp
#include <chrono>
using namespace std;
class timer
public:
timer() : start_timing(hi_res_clock::now()) {}
void reset()
start_timing = hi_res_clock::now();
double elapsed() const
return(std::chrono::duration_cast<second_>
(hi_res_clock::now() - start_timing).count());
private:
typedef std::chrono::high_resolution_clock hi_res_clock;
typedef std::chrono::duration<double, std::ratio<1> >
second_;
std::chrono::time_point<hi_res_clock> start_timing;
Main driving program
#include <iostream>
#include <algorithm>
#include <array>
#include <random>
#include <string>
#include <chrono>
#include "timer.cxx"
#include "print_time.cxx"
// #include "swap.cxx"
// #include "quicksort.cxx"
// #include "print_10.cxx"
int main()
unsigned seed = std::chrono::system_clock::now().time_since_epoch().count();
default_random_engine engine_01(seed);
uniform_real_distribution<double> distribution_01(0.0, 1.0);
string heading;
double t;
timer timer_01;
timer timer_02;
heading = "Program starts";
t = timer_01.elapsed();
print_time(heading, t);
timer_01.reset();
// Size
const int mega_byte = 1024 * 1024;
const int array_size = 128 * mega_byte;
int i;
array<double, array_size> x;
cout << "\n C++ 11 <array> \n" << endl;
cout.width(16);
cout << array_size << endl;
cout.width(16);
cout << (array_size * 8);
cout << " bytes " << endl;
for (i = 0; i < array_size; i++)
x[i] = distribution_01(engine_01);
heading = "Random numbers";
timer_01.reset();
sort(x.begin(), x.end());
heading = "STL sort - <array> ";
timer_01.reset();
heading = "Total time";
t = timer_02.elapsed();
return(0);
The print_time source file is in the original post.
I am in the process of trying to find any compiler switches
that will set the stack size under windows.
Ian_Chivers
Apologies for 'claiming' the solution. I can't find a way to undo that.
SantoshY_Intel
Thanks for posting in the Intel forums.
We were able to reproduce the issue from our end. The issue is with the hexadecimal value being used with the /F option. The use of the hexadecimal value is not being parsed. You can try passing the equivalent integer value which would work fine.
Example:
icx /nologo /O2 main.cpp -o main_icx.exe /F4294967295
Output:
workaround to pass hexadecimal values:
We can use the option: /link -stack:0xffffffff
Example:
icx /nologo /O2 main.cpp -o main_icx.exe /link -stack:0xffffffff
output:
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues. Thank you!
Thanks & Regards,
Santosh
Ian_Chivers
SantoshY_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
