Exception thrown for lapack::potrf call
tdot
Unable to identify why the following code is throwing the exception.  The code is shown below. The debugging back trace is provided in attached file.  Any ideas/help welcome and appreciated.
The following code produces a SIGABORT for the lapack::potrf call
        int64_t nnn = numFeeds * numFeeds;
        std::int64_t scratchSzF = lapack::potrf_scratchpad_size<std::complex<double>>(_queue, uplo::lower, nnn, nnn);
// 0 will be returned if host is CPU, set it to arbitrary size.  Code is running on the host; unit test
        if (scratchSzF == 0) {
          scratchSzF = 10 * nnn;
std::vector<std::complex<double>> input;
        input.clear();
        // numFeeds = 2;  WORKS, no exception thrown if using this input
        // input = {{69.51, 0}, {78.54, 8.3},
        //   {78.54, -8.3}, {89.75, 0}};
        numFeeds = 3; // exception thrown
        input = { {69.51, 0},     {78.54, 8.3},   {85.55, 17.8},
                    {78.54, -8.3},  {89.75, 0},     {98.82, 9.9},
                    {85.55, -17.8}, {98.82, -9.9},  {109.91, 0}};
        // numFeeds = 4; // exception thrown
        // input = {{69.51, 0}, {78.54, 8.3}, {85.55, 17.8}, {88.52, 29.7},
        //   {78.54, -8.3}, {89.75, 0}, {98.82, 9.9}, {103.61, 23},
        //   {85.55, -17.8}, {98.82, -9.9}, {109.91, 0}, {116.64, 13.9},
        //   {88.52, -29.7}, {103.61, -23}, {116.64, -13.9}, {125.55, 0}};
        std::vector<std::complex<double>> scratchPad(scratchSzF, {0.0});
        sycl::buffer<std::complex<double>, 1> inputBuff(input.data(), input.size());
        sycl::buffer<std::complex<double>, 1> scratchBuff(scratchPad.data(), scratchPad.size());
        // factorize THROWS here, Jenkins build reports this:
        // Assertion false failed (located in the cancel function, line in file: 226)
        // Detailed description: Unhandled exception from enqueue task is caught
        lapack::potrf(_queue, uplo::lower, numFeeds, inputBuff, numFeeds, scratchBuff, scratchSzF);
        _queue.wait_and_throw();
        // I added the following  2 lines instead of above.  same SIGABORT issue as above
        //_queue.wait();
        //_queue.throw_asynchronous();
       // Also throws if all 'waits' are commented out
Alex_Y_Intel
Hi @tdot
In order to investigate further, we need a complete reproducer that we can compile and execute to see the problem. Please provide a reproducer and exact commands used to reproduce the issue mentioned.
