Execution aborts after kernel | make: *** [run] Aborted
Singh__Kuljeet
I am trying to run a gaussian blur example on oneAPI dev cloud. I am able to build the example after some tweaking but the execution aborts without throwing any exception or errors. attaching files
u33211@login-1:~/MyFiles/gaussian_blur$ ./q run.sh
Submitting job:
439820.v-qsvr-1.aidevcloud
Job ID                    Name             User            Time Use S Queue
438492.v-qsvr-1            ...ub-singleuser u33211          00:03:04 R jupyterhub
439820.v-qsvr-1            run.sh           u33211                 0 Q batch
Waiting for Output...........
#      Date:           Tue Dec 10 03:16:11 PST 2019
#    Job ID:           439820.v-qsvr-1.aidevcloud
#      User:           u33211
# Resources:           neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
rm -rf ./gaussian-blur.exe
dpcpp gaussian-blur.cpp -o ./gaussian-blur.exe -I. -lOpenCL -lsycl
./gaussian-blur.exe Lenna.png
Gaussian filter created..
Optimal Local Size =64
Starting Kernel..
Finished Kernel..
Makefile:16: recipe for target 'run' failed
# End of output for job 439820.v-qsvr-1.aidevcloud
# Date: Tue Dec 10 03:16:18 PST 2019
Any help is appriciated.
RahulV_intel
Hi Kuljeet,
I have gone through your code. I can see that you haven't specified inputData and outputData argument to the image<2> constructor. Advising you to make the following changes to your code on line numbers 154 and 155.
On line number 154, From cl::sycl::image<2> image_in(co::rgba, ct::unorm_int8, imgRange); (your code)  to        cl::sycl::image<2> image_in(inputData,co::rgba, ct::unorm_int8, imgRange); (suggested change)
On line number 155, From cl::sycl::image<2> image_out(co::rgba, ct::unorm_int8, imgRange); (your code) to        cl::sycl::image<2> image_out(outputData,co::rgba, ct::unorm_int8, imgRange); (suggested change)
Let us know if the suggested changes resolve your issue.
Rahul
Sushma_P_Intel
Hello Kuljeet,
Thanks for reaching out to us. We will get back to you soon.
Sushma
RahulV_intel
Hi Kuljeet,
Rahul
Singh__Kuljeet
Many thanks Rahul,
I was able to execute the code sucessfuly with the changes suggested.
Is there any document that captures the differences / enhancements between DPC++ and SYCL1.2 ?
Kaleem_A_Intel
Hi Kuljeet,
Good to know that your issue is resolved. We are closing this thread.
Request you to raise a new thread for "Is there any document that captures the differences/enhancements between DPC++ and SYCL1.2 ?" query.
Kaleem
