FP16 math functions not getting inlined
rabbits
icx 2024.2.0
-Ofast -xSAPPHIRERAPIDS
#include <immintrin.h>
#include <mathimf.h>
_Float16 test_fp16(_Float16 x, _Float16 y)
    return sqrtf16(x) + sqrtf16(y);
generates the following code:
test_fp16(_Float16, _Float16):
        push    rax
        vmovsh  word ptr [rsp + 4], xmm1
        call    sqrtf16
        vmovsh  word ptr [rsp], xmm0
        vmovsh  xmm0, word ptr [rsp + 4]
        call    sqrtf16
        vaddsh  xmm0, xmm0, word ptr [rsp]
        pop     rax
        ret
Is there a compiler flag I can use to make it generate the expected code instead?
        vsqrtsh xmm0, xmm0, xmm0
        vsqrtsh xmm1, xmm1, xmm1
        vaddsh  xmm0, xmm1, xmm0
        ret
See https://godbolt.org/z/xWsqW8djE for more details.
Alex_Y_Intel
I've escalated your issue to our internal team for further investigation, thanks.
Alex_Y_Intel
In order for a function to be inlined, it has to have the header/source file when compiling. If you take a look at the "inline report" with: icx test.c -Ofast -xSAPPHIRERAPIDS -c -qopt-report=3 -qopt-report-file=stderr
Global optimization report for : test_fp32
Global optimization report for : test_fp16
Global optimization report for : test_fp16_fix
---- Begin Inlining Report ----
Option Values:
 inline-threshold: 225
 inlinehint-threshold: 325
 inlinecold-threshold: 45
 inlineoptsize-threshold: 15
DEAD STATIC FUNC: _mm_set_sh
DEAD STATIC FUNC: _mm_setzero_ph
DEAD STATIC FUNC: _mm_sqrt_sh
DEAD STATIC FUNC: sqrtf16_fast
COMPILE FUNC: test_fp32
  -> llvm.sqrt.f32 test.c (6,12)
  -> llvm.sqrt.f32 test.c (6,23)
COMPILE FUNC: test_fp16
  -> EXTERN: sqrtf16 test.c (11,12)
  -> EXTERN: sqrtf16 test.c (11,25)
COMPILE FUNC: test_fp16_fix
  -> INLINE: sqrtf16_fast test.c (21,12) (-30<=487)
   -> INLINE: _mm_sqrt_sh test.c (16,12)
     -> INLINE: _mm_setzero_ph test.c
     -> llvm.sqrt.f16 test.c
   -> INLINE: _mm_setzero_ph test.c (16,24)
   -> INLINE: _mm_set_sh test.c (16,42)
  -> INLINE: sqrtf16_fast test.c (21,30) (-30<=487)
---- End Inlining Report ------
Please note that sqrtf16 uses an external function:
In fact, this sqrtf16 is actually extracted from libimf.a and linked by the linker, and libimf.a is a library object, not a header/source file.
In conclusion, icx does not provide the source code for sqrtf16 to be inlined.
rabbits
swell!
Alex_Y_Intel
I'm discussing this problem with another team and trying to find if we have other solutions.
rabbits
Let me turn Gordon in his grave for you.
