Ankündigungen
FP16 math functions not getting inlined
rabbits
Einsteiger
2.027Aufrufe
icx 2024.2.0
-Ofast -xSAPPHIRERAPIDS
#include <immintrin.h>
#include <mathimf.h>
_Float16 test_fp16(_Float16 x, _Float16 y)
    return sqrtf16(x) + sqrtf16(y);
generates the following code:
test_fp16(_Float16, _Float16):
        push    rax
        vmovsh  word ptr [rsp + 4], xmm1
        call    sqrtf16
        vmovsh  word ptr [rsp], xmm0
        vmovsh  xmm0, word ptr [rsp + 4]
        call    sqrtf16
        vaddsh  xmm0, xmm0, word ptr [rsp]
        pop     rax
        ret
Is there a compiler flag I can use to make it generate the expected code instead?
        vsqrtsh xmm0, xmm0, xmm0
        vsqrtsh xmm1, xmm1, xmm1
        vaddsh  xmm0, xmm1, xmm0
        ret
See https://godbolt.org/z/xWsqW8djE for more details.
5 Antworten
Alex_Y_Intel
1.957Aufrufe
I've escalated your issue to our internal team for further investigation, thanks.
Alex_Y_Intel
1.932Aufrufe
In order for a function to be inlined, it has to have the header/source file when compiling. If you take a look at the "inline report" with: icx test.c -Ofast -xSAPPHIRERAPIDS -c -qopt-report=3 -qopt-report-file=stderr
Global optimization report for : test_fp32
Global optimization report for : test_fp16
Global optimization report for : test_fp16_fix
---- Begin Inlining Report ----
Option Values:
 inline-threshold: 225
 inlinehint-threshold: 325
 inlinecold-threshold: 45
 inlineoptsize-threshold: 15
DEAD STATIC FUNC: _mm_set_sh
DEAD STATIC FUNC: _mm_setzero_ph
DEAD STATIC FUNC: _mm_sqrt_sh
DEAD STATIC FUNC: sqrtf16_fast
COMPILE FUNC: test_fp32
  -> llvm.sqrt.f32 test.c (6,12)
  -> llvm.sqrt.f32 test.c (6,23)
COMPILE FUNC: test_fp16
  -> EXTERN: sqrtf16 test.c (11,12)
  -> EXTERN: sqrtf16 test.c (11,25)
COMPILE FUNC: test_fp16_fix
  -> INLINE: sqrtf16_fast test.c (21,12) (-30<=487)
   -> INLINE: _mm_sqrt_sh test.c (16,12)
     -> INLINE: _mm_setzero_ph test.c
     -> llvm.sqrt.f16 test.c
   -> INLINE: _mm_setzero_ph test.c (16,24)
   -> INLINE: _mm_set_sh test.c (16,42)
  -> INLINE: sqrtf16_fast test.c (21,30) (-30<=487)
---- End Inlining Report ------
Please note that sqrtf16 uses an external function:
In fact, this sqrtf16 is actually extracted from libimf.a and linked by the linker, and libimf.a is a library object, not a header/source file.
In conclusion, icx does not provide the source code for sqrtf16 to be inlined.
rabbits
Einsteiger
1.912Aufrufe
swell!
Alex_Y_Intel
1.861Aufrufe
I'm discussing this problem with another team and trying to find if we have other solutions.
rabbits
Einsteiger
1.834Aufrufe
Let me turn Gordon in his grave for you.
Antworten
