Floating Point gets miscompiled.
Mysticial
Compiler: Intel(R) oneAPI DPC++/C++ Compiler 2025.0.0 (2025.0.0.20241008)
OS: Windows (via Visual Studio 17.11.5)
The following code is incorrectly compiled:
#include <iostream>
using std::cout;
using std::endl;
#define NO_INLINE       __declspec(noinline)
#define FORCE_INLINE    inline __forceinline
class Object{
public:
    FORCE_INLINE Object(uint64_t x) : Object(nullptr, (uint32_t)x, (double)(uint32_t)(x >> 32) * 4294967296.) {}
    FORCE_INLINE Object(void*, double L, double H){
        double r0;
        r0 = (double)(L + H);
        hi = r0;
        r0 = (double)(r0 - H);
        lo = (double)(L - r0);
    double lo;
    double hi;
NO_INLINE Object func(const Object& a){
    return a;
NO_INLINE void test_function(uint32_t k){
    uint64_t stop = (uint64_t)1 << k;
    stop /= 4;
    for (uint64_t c = 0; c < stop; c++){
        Object obj = func(c);
        cout << "c = " << c << ": obj = " << obj.hi << endl;
int main(){
    test_function(9);
Compiler Flags:
/GS /W3 /QxAVX /Gy /Zc:wchar_t /Zi /O3 /fp:precise /D "NDEBUG" /D "_CONSOLE" /D "__INTEL_LLVM_COMPILER=20250000" /D "_UNICODE" /D "UNICODE" /Qipo /Zc:forScope /Oi /MD /Fa"x64\Release\" /EHsc /nologo /Fo"x64\Release\" /Fp"x64\Release\ICX2025 Miscompile 1.pch"
Expected Output:
c = 0: obj = 0
c = 1: obj = 1
c = 2: obj = 2
c = 3: obj = 3
c = 4: obj = 4
c = 5: obj = 5
c = 6: obj = 6
c = 7: obj = 7
Actual Output:
c = 0: obj = 0
c = 1: obj = 6.95222e-310
c = 2: obj = 8.04776e-312
c = 3: obj = 8.04776e-312
c = 4: obj = 6.1857e-321
c = 5: obj = 1.7407e-315
c = 6: obj = 1.26481e-321
c = 7: obj = 3.95253e-323
yzh_intel
Hi, I reproduced the issue, it seems that the compiler performed some incorrect optimization. I have escalated the issue to compiler engineering team. Thanks for reporting issues to us.
Meanwhile, can you try to set the optimization level to /O2 instead of /O3? In my testing, the case passes with /O2.
yzh_intel
Hi @Mysticial I'd like to let you know that the issue has been fixed in compiler 2025.1, please let us know if you still see any issue.
