How to understand this `handler`
Klen
We can use both `buffers` and `USM` implementations in `oneapi`,
In `USM`:
queue q;
int *data1 = malloc_shared<int>(128, q);
for (int i = 0; i < N; i++) {
data1[i] = 10;
auto e1 = q.parallel_for(range<1>(N), [=](id<1> i) { data1[i] += 2; });
We use `q.parallel_for` to do parallel computing.
In `buffers`
std::vector<int> vector1(128, 10);
buffer vector1_buffer(vector1);
queue q;
q.submit([&](handler &h) {
    accessor vector1_accessor (vector1_buffer,h);
    h.parallel_for(range<1>(N), [=](id<1> index) {
        vector1_accessor[index] += 1;
We pass `handler` to the lambda function and use `h.parallel_for` to do parallel computing.
My question is what is handler, how do I understand it? What is the different between `handler` and `queue`?
VaishnaviV_Intel
Thank you for posting in Intel communities.
A command group usually contains code, that defines dependences running as part of the host program (so that the runtime knows what the dependences are) and device code running in the future once the dependences are satisfied.
A command group handler gives more control over how code is submitted to the queue.
A DPC++ queue is employed to schedule and execute the command queues on the devices.
Queue also uses a shortcut method that directly invoke parallel_for on the queue object instead of inside a lambda passed to the submit method (a command group).
Queues are used to schedule the execution of a set of handlers, ensuring that dependencies between commands are correctly managed.
The handler encapsulates the details of a single parallel computation, while the queue manages the execution of a set of handlers.
Please refer to the Data parallel C++ Textbook by James Reinders for more details.
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
Thanks & Regards,
VaishnaviV_Intel
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
VaishnaviV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
