ICC/ICX compiler bugs (change registgers)
hyungseok
I found that ICX 2024.0.0 and ICC 2021.10.0 change registers without any alarm messages.
This error has been identified in 3 opcodes (lar, movmskpd, pmovmskb) in ICX and in 6 opcodes (lar, mov, movmskpd, pmovmskb, sldt, str) in ICC.
Buggy Code
void bug(int num) {
__asm__(".intel_syntax noprefix\n"
"lar R11, R8W\n"
"mov R10, GS\n"
"movmskpd R9, XMM0\n"
"pmovmskb R10, MM2\n"
"sldt R15\n"
"str R8\n"
Compiled Code (ICX 2024.0.0)
You can reproduce the result through the godbolt:
https://godbolt.org/z/1Md7Ysv73
bug:
push rbp
mov rbp,rsp
mov DWORD PTR [rbp-0x4],edi
lar r11,r8
mov r10,gs
movmskpd r9d,xmm0
pmovmskb r10d,mm2
sldt r15
str r8
pop rbp
ret
Compiled Code (ICC 2021.10.0)
https://godbolt.org/z/5os84qzWh
bug:
push rbp
mov rbp,rsp
sub rsp,0x10
mov DWORD PTR [rbp-0x10],edi
lar r11,r8
mov r10d,gs
movmskpd r9d,xmm0
pmovmskb r10d,mm2
sldt r15d
str r8d
leave
ret
Alex_Y_Intel
I've escalated your problem to our internal team. Please note that ICC has been deprecated and removed from our oneAPI Base Toolkit since later versions in 2023. Please migrate to using ICX compiler instead.
Alex_Y_Intel
This is not a defect. All compilers behave the same https://godbolt.org/z/TEqd7qYh9
