891 Discussions
ICX/ICC compiler Assembly code parsing errors.
hyungseok
I found that ICX 2024.0.0 and ICC 2021.10.0 identified memory operands as immediate value.
This error has been identified in 5 opcodes (loop, loope, loopne, jecxz, jrcxz).
Also, ICX and ICC have same errors when it generates x86 and x64 binaries.
Buggy Code
void bug(int num) {
__asm__(".intel_syntax noprefix\n"
"loop XMMWORD PTR [1]\n"
"loope XMMWORD PTR [1]\n"
"loopne XMMWORD PTR [1]\n"
"jrcxz XMMWORD PTR [1]\n"
"jecxz YMMWORD PTR [1]\n"
Compiled Code
bug:
push rbp
mov rbp,rsp
sub rsp,0x10
mov DWORD PTR [rbp-0x10],edi
loop d <bug+0xd>
R_X86_64_PC8 *ABS*
loope f <bug+0xf>
R_X86_64_PC8 *ABS*
loopne 11 <bug+0x11>
R_X86_64_PC8 *ABS*
jrcxz f <bug+0xf>
R_X86_64_PC8 *ABS*
jecxz 12 <bug+0x12>
R_X86_64_PC8 *ABS*
leave
ret
You can reproduce the errors through godbolt site.
ICX: https://godbolt.org/z/1TPMYMYEv
ICC: https://godbolt.org/z/cWqbbTdEh
Alex_Y_Intel
I've escalated your issue to our internal engineering team.
Alex_Y_Intel
All compilers ICC/ICX/GCC generate the same thing. It is not a bug.
https://godbolt.org/z/GMP7TcTeh
