891 Discussions
Intel error: clang frontend command failed with exit code 139"
aruhela
Compiling FlowSieve https://github.com/husseinaluie/FlowSieve) on TACC Stampede3 generates the CLANG error.  The issue persists with 2024.1 as well and with -O1 optimization flags. Can someone take a look at the attached error reports and suggest a fix?
Alex_Y_Intel
@aruhela I'm escalating your issue to our engineer team and we'll work on it internally. I'll come back with update when we reach a solution.
cw_intel
I tested the code you provided.
I can build the code using -fopenmp option,
$ icpx -c -fopenmp icpx_diagnostic_log.cpp
But get the error you reported with -fiopenmp option,
$ icpx -c -fiopenmp icpx_diagnostic_log.cpp
icpx: error: clang frontend command failed with exit code 139 (use -v to see invocation)
We will report the bug to our internal team. ​As a workaround, can you try if you can build the application with "-fopenmp" option?
cw_intel
This issue has been fixed in the latest compiler 2024.2. Can you try the latest compiler and let us know if your issue is solved?
fabianw1
I am still getting this the same clang frontend error using 2024.2.  I only get this error when I use the `-fno-alias` option.  Without this option the code builds.  I am attaching the error logs below.  Thanks for your time.
