881 Discussions
Intel oneAPI dpcpp compiler with google test
noorpari76
I'm kind a new to the world of Intel's HPC toolchain and I'm facing some troubles making even simple DPC++ application to work when gtest is used as a testing framework
This is the CMakeLists "structure" I'm following
cmake_minimum_required(VERSION 3.14)
project(foo)
set(CMAKE_CXX_COMPILER "dpcpp")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++17 -O3 -fsycl")
# add executables
# target linked libraries
option(ENABLE_TESTS ON)
if(ENABLE_TESTS)
  FetchContent_Declare(
    googletest
    GIT_REPOSITORY https://github.com/google/googletest.git
    GIT_TAG release-1.11.0
  set(gtest_force_shared_crt ON CACHE BOOL "" FORCE)
  FetchContent_MakeAvailable(googletest)
  add_subdirectory(tests)
endif()
If I remove the last block. it compiles and runs as expected, otherwise I get the following error:
CMake Error at build/_deps/googletest-src/CMakeLists.txt:10 (project):
  The CMAKE_CXX_COMPILER:
    dpcpp
  is not a full path and was not found in the PATH.
  Tell CMake where to find the compiler by setting either the environment
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
-- Configuring incomplete, errors occurred!
See also "/home/u141905/foo/build/CMakeFiles/CMakeOutput.log".
See also "/home/u141905/foo/build/CMakeFiles/CMakeError.log".
You have changed variables that require your cache to be deleted.
Configure will be re-run and you may have to reset some variables.
The following variables have changed:
CMAKE_CXX_COMPILER= /usr/bin/c++
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
make: *** [Makefile:2: all] Error 1
Please notice that dpcpp is correctly set, in fact I'm using Intel's devcloud platform. Setting CXXto the output of whereis dpcpp produces the same error. The only "workaround" (I doubt it is one though) I found is using clang++ instead (the version from Intel's llvm). Any help or suggestion is much appreciated, thanks in advance!
HemanthCH_Intel
Please use the path for dpcpp binary for setting the CMAKE_CXX_COMPILER instead of using"set(CMAKE_CXX_COMPILER "dpcpp")". After adding the path("/opt/intel/oneapi/compiler/2022.0.1/linux/bin/dpcpp") to the CMAKE_CXX_COMPILER, we are able to run the program successfully.
Please find the below CMakeLists.txt for setting the CMAKE_CXX_COMPILER:
project(foo)
set(CMAKE_CXX_COMPILER "/opt/intel/oneapi/compiler/2022.0.1/linux/bin/dpcpp")
# add executables
set(ENABLE_TESTS ON)
include(FetchContent)
if(ENABLE_TESTS)
  googletest
endif()
The output of the above code:
Thanks & Regards,
Hemanth
HemanthCH_Intel
We haven't heard back from you. Could you please provide any updates on your issue?
Thanks & Regards,
Hemanth
HemanthCH_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth
