806 Discussions
Why can't use image accessor to read value of other types
shenuo
I see the accessor.hpp (line 417)
static_assert(std::is_same<DataT, cl_int4>::value ||
std::is_same<DataT, cl_uint4>::value ||
std::is_same<DataT, cl_float4>::value ||
std::is_same<DataT, cl_half4>::value,
"The data type of an image accessor must be only cl_int4, "
"cl_uint4, cl_float4 or cl_half4 from SYCL namespace");
is that mean the data can only be these types?  if I want read a 1 channel image with pixel of 8 bit by using image accessor  ,
what should I do?
NoorjahanSk_Intel
As of now the supported data type for image accessors are
int4
uint4
float4
half4
We will check with the concerned team and get back to you with an update.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We have reported this issue to the development team, they are looking into this issue
Thanks & Regards,
Noorjahan.
