Issues with oneAPI Base toolkit
gib
새로운 기여자 II
9,091 조회수
First I tried installing the toolkit on a Windows 7 machine.  The installation failed immediately because api-ms-win-shcore-scaling-l1-1-1.dll was missing.
I then installed successfully on a Windows 10 machine.  I don't know if this is because it's W10 or because it also has VS 2019 installed.  Anyway, so far so good.
I built the vector-add sample program (I first had to unset 'read-only' on the directory to allow mkdir), but when I run it the program fails:
info: internal compiler error
NMAKE : fatal error U1077: '.\vector-add-buffers.exe' : return code '0x01'
0 포인트
17 응답
RahulV_intel
중재자
9,075 조회수
Windows 7 is not supported by oneAPI. Please check the system requirements here:
https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-base-toolkit-system-requirements.html
Could you please specify your Visual Studio version on Windows 10?
Also, mention the steps you have followed to build/run the sample.
Please refer to the link below to build/run the samples on the command line:
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-windows/top/run-a-sample-project-using-the-visual-studio-command-line.html
Get started link (Windows):
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-windows/top.html
Rahul
0 포인트
gib
새로운 기여자 II
9,060 조회수
Thanks for responding, Rahul.
I followed these command line build and run instructions:
To build: nmake -f makefile.win
To run: nmake -f makefile.win run
The build was successful, creating vector-add-buffers.exe (339 KB)
I have both VS2012 and VS2019 - I don't know which nmake was used.
For some reason two VS project files were created, vector-add-buffers.vcxproj and vector-add-usm.vcxproj.  They both contain the same two projects, and build x64\release\vector-add-buffers.exe and x64\release\vector-add-usm.exe.
I can't recall where I saw the instructions to use nmake for the build and run, but now I have done this with MSBuild:
MSBuild vector-add.sln /t:Rebuild /p:Configuration="Release"
This uses VS2019 creates vector-add-buffers.exe and vector-add-usm.exe, but not vector-add.exe.  There is one warning but no errors.
0 포인트
RahulV_intel
중재자
9,019 조회수
Does it run in the scenario or are you facing the same issue again?
Could you please try to build/run the simple vector add code below:
#include <CL/sycl.hpp>
#include <iostream>
#include <vector>
using namespace sycl;
#define size 1024
int main() {
    std::vector<int> A(size, size), B(size, size), C(size, 0);
    { //SYCL scope begins
        queue q;
        range<1> R(size);
        buffer<int,1> buffA(A.data(), R);
        buffer<int,1> buffB(B.data(), R);
        buffer<int,1> buffC(C.data(), R);
		std::cout<< "Running on: "<<q.get_device().get_info<info::device::name>()<<"\n";
        q.submit([&](handler &cgh) {
            auto acc_buffA = buffA.get_access<access::mode::read>(cgh);
            auto acc_buffB = buffB.get_access<access::mode::read>(cgh);
            auto acc_buffC = buffC.get_access<access::mode::write>(cgh);
            cgh.parallel_for(R, [=](id<1> i) {
                acc_buffC[i] = acc_buffA[i] + acc_buffB[i];
    } //SYCL scope ends
    std::vector<int> vecValidate(size, 2*size);
    (C==vecValidate) ? std::cout << "Success\n" : std::cout<<"Failure\n";
    return 0;
Steps to build and run the code:
  • Open the "Intel oneAPI command prompt for Visual Studio-19" in order to automatically source the oneAPI environment.
  • If you do not find the oneAPI command prompt, to manually source the oneAPi environment, open the usual Microsoft command prompt and execute the below command (From oneAPI_root installation directory):
cd "C:\Program Files (x86)\Intel\oneAPI" && setvars.bat
  • To build and run:
dpcpp simplevecadd.cpp -o sva.exe && sva.exe
Let us know if you face any issues.
Rahul
0 포인트
RahulV_intel
중재자
9,006 조회수
Were you able to run the vector-add code sample? (attached in the previous post)
Rahul
0 포인트
gib
새로운 기여자 II
8,996 조회수
Hi Rahul,
Problems persist.
  1.  I tried to make the directory for vector-add a subdirectory of oneAPI.  I did not have permission for this.  So I created that directory first, then ran oneapi-cli again.  This led to another permission issue - no permission to write there.  So I changed the permissions and was able to run oneapi-cli and finally run MSBUILD.  I have attached the output from the build.  Both vector-add-buffers.exe and vector-add-usm.exe are created.
  2. When I run either of the executables I get an error message saying that sycl.dll is not found.
I should add (in case it's not obvious) that I didn't install oneAPI at the default location, because my C drive is pretty full. Instead I installed it at F:\oneAPI.
I added the location of sycl.dll (F:\oneapi\compiler\2021.2.0\windows\bin) to the PATH, and now the execution fails in a different way:
The application was unable to start correctly (0xc000007b).
At this stage I would usually run Dependency Walker, but it doesn't work with Windows 10.  Suggestions?
0 포인트
gib
새로운 기여자 II
8,990 조회수
I increased the permissions on the bin directory, and now both executables fail with a different message - an exception is caught.
The permissions issues are a pain, because the user doesn't know what is needed.  I have never had this problem before when installing software.  Maybe it works on Linux but nobody has paid much attention to Windows.
0 포인트
RahulV_intel
중재자
8,972 조회수
>> The permissions issues are a pain because the user doesn't know what is needed.
Running the command prompt as an administrator might help in this case. (Right-click on the cmd application and select "Run as administrator")
Could you please attach a screenshot of the message displayed?
Rahul
0 포인트
gib
새로운 기여자 II
8,964 조회수
Error message attached
0 포인트
RahulV_intel
중재자
8,917 조회수
Could you please attach the SYCL_PI_TRACE logs by setting the environment variable as follows:
set SYCL_PI_TRACE=2
Once you set this environment variable, run the executable as usual to see the Debug output.
Rahul
0 포인트
gib
새로운 기여자 II
8,910 조회수
There is no output.  It would help if you told me where to find the log file.
0 포인트
RahulV_intel
중재자
8,894 조회수
Since you are facing the issues at runtime, the SYCL_PI_TRACE log will contain information about the low-level API invoked during runtime.
Please redirect the output to a text file and attach the same.
Command:
set SYCL_PI_TRACE=2 && your_app.exe
Rahul
0 포인트
RahulV_intel
중재자
8,857 조회수
Just a quick reminder to attach the PI_TRACE logs.
Rahul
0 포인트
gib
새로운 기여자 II
8,849 조회수
As I said before, I do not know where to find these logs.  There is no program output as it fails immediately.
0 포인트
Viet_H_Intel
중재자
8,824 조회수
Can you let us know which version of VS2019 you have?
0 포인트
Viet_H_Intel
중재자
8,673 조회수
Is your issue resolved? if not, can you let us know which VS2019 version you are currently using? The reason I asked is because some versions of VS are not yet supported by Intel compiler. Please see this link https://software.intel.com/content/www/us/en/develop/articles/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
0 포인트
Viet_H_Intel
중재자
8,613 조회수
Let us know if you still having issue. If not, we would like to close this thread in the next few days.
0 포인트
Viet_H_Intel
중재자
8,576 조회수
Let's close this case. We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
0 포인트
응답
