Macro to target specific backend in kernel
VinInn
Is there any specific oneAPI macro (or other compile time construct as macros seem to be interpreted at dpcpp step) to specifically target a given backend/platform (gpu, cpu) in a kernel (JIT compiled)?
something like
#ifdef ON_CPU
  // some code that does not compile on GPU (or is optimized for CPU)
#elif ON_GPU
 // an alternative for the GPU
#else
 // throw?
#endif
NoorjahanSk_Intel
>>Is there any specific oneAPI macro..
Please find the sample code and steps we have followed to target specific devices from our end.
vec_add.cpp:
#include <CL/sycl.hpp>
#include <iostream>
#include <vector>
using namespace sycl;
#define size 1024
int main() {
std::vector<int> A(size, size), B(size, size), C(size, 0);
queue cpuQ(cpu_selector{});
queue gpuQ(gpu_selector{});
range<1> R(size);
buffer<int,1> buffA(A.data(), R);
buffer<int,1> buffB(B.data(), R);
buffer<int,1> buffC(C.data(), R);
#ifdef CPU
std::cout<<"Running on: "<<cpuQ.get_device().get_info<sycl::info::device::name>()<<"\n";
cpuQ.submit([&](handler &cgh) {
auto acc_buffA = buffA.get_access<access::mode::read>(cgh);
auto acc_buffB = buffB.get_access<access::mode::read>(cgh);
auto acc_buffC = buffC.get_access<access::mode::write>(cgh);
cgh.parallel_for(R, [=](id<1> i) {
acc_buffC[i] = acc_buffA[i] + acc_buffB[i];
#elif GPU
std::cout<<"Running on: "<<gpuQ.get_device().get_info<sycl::info::device::name>()<<"\n";
gpuQ.submit([&](handler &cgh) {
#endif
std::vector<int> vecValidate(size, 2*size);
(C==vecValidate) ? std::cout << "Success\n" : std::cout<<"Failure\n";
return 0;
Command to execute:
dpcpp vec_add.cpp -DCPU -o cpuadd && ./cpuadd
dpcpp vec_add.cpp -DGPU -o gpuadd && ./gpuadd
Please find the attached screenshot for more details:
We use the -D option to define a macro name while compiling the source code.
Please refer to the below link for more details:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/compiler-options/compiler-option-details/preprocessor-options/d.html
We can target specific backend using the SYCL_DEVICE_FILTER environment variable.
Syntax:
export SYCL_DEVICE_FILTER=backend:device_type:device_num
Possible values of backend are:
host
level_zero
opencl
Possible values of device_type are:
host
cpu
gpu
acc
device_num is an integer that indexes the enumeration of devices from the sycl-ls utility tool and will return all devices with an index from all different backends.
Please find below link for more details:
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/oneapi-programming-model/device-selection.html
Thanks & Regards,
Noorjahan
NoorjahanSk_Intel
HI,
Has the information provided above helped? If yes, Could you please confirm whether we can close this thread from our end?
Thanks & Regards,
Noorjahan.
VinInn
I understood that what I had in mind cannot be done,
will do otherwise.
thanks for the help.
Please close the thread.
NoorjahanSk_Intel
Could you please elaborate more on your issue so that we will try to help you in another way?
Thanks & Regards,
Noorjahan.
VinInn
Say I have a kernel that I want to run on GPU and CPU but a small part I wish to use an optimized routine that will NOT compile in the other and I do not wnat (as in your example) to duplicate all the code and I do not want to split my kernel
this will not work.
auto kernel = [=](auto i,....) {
// a lot of code
#ifdef ONGPU
  optimizedForGPU  // may not parse on HOST
#else
 optimizedForCPU
#endif
// more code
VinInn
In any case my questions were:
1) can macros be used in a sycl kernels to drive JIT compilation?
My understanding is: NO, they are parsed by the host compiler ahead-of-time (a in your example)
2) is there any other mechanism in sycl to compile part of a kernel for a specific target?
my understanding is: NO, there is no "special" mechanism in sycl to perform JIT conditional compilation.
Thanks again for the support and please close the thread.
NoorjahanSk_Intel
>>Thanks again for the support. please close the thread
We have discussed this case with concerned team and they are interested to get some more details. So, could you please let us know is there any particular
use-case behind compiling part of the kernel on a specific target so that we could check the possibilities internally and will try to address your questions specifically?
Before proceeding further in closing this thread as per your request,
I think it would also become a good reference to anybody looking at this topic with similar thoughts as yours by providing your use-case.
Thanks & Regards,
Noorjahan.
VinInn
for instance in some kernel I run either on GPU or on CPU under cuda/nvcc at some point I need to perform a sort  and I use CUDA_ARCH to select either a bucket-sort for GPU (single block) or  quick sort on CPU (single thread).
NoorjahanSk_Intel
Could you please provide us a sample reproducer with CUDA_ARCH, so that we can understand it better?
Thanks & regards,
Noorjahan.
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Could you please confirm whether your are using nvrtc Cuda runtime library in your application?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We have reported this issue to the development team, they are looking into this issue.
Thanks & Regards,
Noorjahan.
