855 Discussions
No /MT option in Runtime Library field in VC2022 with Intel OneAPI DPC++ compiler 2023
barry-waves
After selecting intel oneAPI DPC++ Compiler 2023 (version is 2023.2) in Platform Toolset in VC2022, there is no "Multi-threaded (/MT)" option in Configuration Properties -> DPC++ -> Code Generation-> Runtime Library.
But it seems that it should support /MT option. Could you please give some advice to have /MT option? Thanks.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-windows/2023-2/linking-with-compiler-run-time-libraries.html
https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2023-0/mt.html
Best regards
Barry
Labels (2)
SeshaP_Intel
Intel oneAPI DPC++ Compiler will not support /MT option. Hence, We cannot add the /MT option with the DPC++ project as it is not supported in the DPC++ toolchain, which means static library could not be supported.
But you can use "Intel C++ Compiler 2023" for the /MT option for the C++ Project.
Please refer to the Note in the below link.
https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2023-2/mt.html
Please let us know if you have any issues.
Thanks and Regards,
Pendyala Sesha Srinivas
barry-waves
SeshaP_Intel
>> Thank you for elaborating.
As your issue was resolved, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
SeshaP_Intel
As your issue was resolved, I am going ahead and closing this case. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
